Go Back   Automotive Forums Car Chat > Mazda > RX-7
Old 11-27-2004, 07:21 AM
fcdriver fcdriver is offline
Re: Faq Thread
D3rELic is right we should get things approved before we start posting more just to be sure everything is on the line.
With that said I was wondering how everyone felt about adding pettitracing.com and RX7.com to the list for RX7 performance sites?
Old 11-28-2004, 05:33 PM
mcs mcs is offline
Send a message via MSN to mcs
Re: Faq Thread
sorry i was just doing fuel consumptions on avarage that i mostly hear...
your cars fast, but mines faster!.
Old 12-10-2004, 11:42 AM
D3rELiC's Avatar
D3rELiC D3rELiC is offline
Re: Faq Thread
watcha think of this one ?
WHY NOT USE SYNTETIC OIL ON STOCK ENGINE :
syntetic oil as aditives that arnt designed to burn
rotary engine has a device to lube up the seals, an oil meetering pump (OMP) shoots oil in the rotor chamber, its called an oil meetering pump, unless you have removed that pump (and you are runing premixed oil in your gaztank), running syntetic oil will leave shit in the engine therefore reducing power and life time.
Old 12-10-2004, 11:17 PM
89tracerman's Avatar
89tracerman 89tracerman is offline
Re: Re: Faq Thread
royal purple is a syntetic oil and it works fine on RX7's you should also specify what is a pre mix.
my cardomain
Old 12-11-2004, 11:50 AM
k2dogg86 k2dogg86 is offline
Re: Faq Thread
I just bought an 87 RX7 for $900. Perfect exterior and decent interior. The only major problem with this car is that it has a 3,800 rpm hesitation. Would it be the fuel injectors, spark plugs, exhaust, cold solder points in the cpu? What! Does anyone accually know the answer or have a clue? HELP!
Old 12-11-2004, 12:06 PM
Re: Faq Thread
If you add aftermarket mufflers and an intake to a RX7, wouldnt it run rich? If it runs rich, what kind of hardware would you invest in to control it. If it runs too rich, the apex seals will burn out faster. Right or wrong?
Old 12-12-2004, 10:46 PM
D3rELiC's Avatar
Re: Faq Thread
k2dogg86 : no your car will run fine after intake/exhaust mods, T2s and FDs are another story
from the FC FAQ on the rx7club.com :
I have this hesitation whenever I accelerate right around 3500-4000 RPM
The dreaded 3800 RPM hesitation is cause 90% of the time by poor ground connections between the engine, the battery, and the car. Clean or replace all the under hood ground connections. Some people have also claimed replacing/regrounding the pressure sensor's ground wire has helped. If there is still a problem after that, look at cleaning the fuel injectors and (on a N/A) that your 5th/6th ports are operating correctly.
Old 12-26-2004, 03:25 AM
Re: Faq Thread
Some intersting facts and specs on third gen RX7 that should be looked to go in the FAQ section, http://www.turborx7.com/rx7specs.htm
Old 12-26-2004, 05:40 PM
Re: Faq Thread
sounds good!!!^^^^
my cardomain
Old 12-28-2004, 12:12 PM
drftk1d's Avatar
drftk1d drftk1d is offline
boost in, apex seals out
Send a message via AIM to drftk1d
Re: Re: Re: Faq Thread
Pre-mix: mix motor oil and fuel so that they can be injected into the chambers at combustion time. It is advantageous because the rotary burns a little oil by design. You can remove the OMP to do this, but its not always necessary.
http://www.nopistons.com/forums/inde...T&f=65&t=14446
RX-7 TII
Old 12-28-2004, 08:58 PM
Re: Faq Thread
post!!! ^^^^^
my cardomain
Old 02-07-2005, 07:34 PM
D3rELiC's Avatar
Re: Faq Thread
posted a link list, if i have missed something, feel free to put the link in here, i'll edit my post
