Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 11-03-2004, 06:36 PM
SSZero's Avatar
SSZero SSZero is offline
Re: My first upgrade to a stock GST should be...
Which shift kit? And do you mean to switch my auto to a manual or something else? If it's auto to manual, forget it. I don't want to have ECU problems and be in the shop every week...
'96 Green Eclipse GS-T
Stock for now...
Old 11-03-2004, 07:47 PM
Partizan's Avatar
Partizan Partizan is offline
No they have kits to make your auto shift at higher rpms. I wouldn't recommend it if it's a mainly daily driver though.
Old 11-03-2004, 10:30 PM
kjewer1 kjewer1 is offline
AF - Advisor
Shift kits arent to make it shift at higher rpm, its make make it shift under higher fluid pressure. Typical mods are shift kit, end clutches, and springs. I've had shift kits/springs in all of my non-dsm daily drivers, I like a lot better than stock!
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 11-03-2004, 11:05 PM
SSZero's Avatar
Wow, that sounds interesting... I guess I'll check it out, but is there anything special I have to get before the shift kits or something?
Stock for now...
Old 11-04-2004, 09:55 AM
AF - Advisor
Money? Balls? Yeah, thats about all I cant think of. Make sure a competent transmission shop does the work. Some poeple prefer to spend the bucks and have someone like www.importperformancetrans.com do it. Thats your call. There are local shops that are capable, just make sure you find one.
Kevin Jewer
Old 11-04-2004, 03:28 PM
Partizan's Avatar
Whoops, I thought that it made your auto shift higher? Thanks for correcting me though Kevin. Never really dealt with an auto just read about them.
Old 11-04-2004, 09:31 PM
tavarish tavarish is offline
Send a message via AIM to tavarish
do a full tuneup, then after that, get a downpipe. Do the free mods, i dont know what they are, I don't have a DSM...screw around with boost pressure, just remember that the T25 turbo does bad at high psi....loses efficiency FAST. Don't get an ECU...yet, because you'll have to reprogram it after any major mod you might get. Do a drop resistor mod with a WOT switch to make your auto tranny run at full line pressure at WOT. It will shift harder, but it's actually better for your tranny and cut down your e/t. Also, minor things like grounding wores, spark plugs, and fuel filters arents bad to increase performace either. When you go down to the track, lower your tire pressure to about 25psi. I wouldn't recommend beating on your car as a daily driver though....that's just foolish.
Old 11-06-2004, 07:57 PM
97_3clipse's Avatar
97_3clipse 97_3clipse is offline
Send a message via AIM to 97_3clipse
i think your mods are BS, a downpipe first?!? come on! you dont even have a DSM...
1998 Eagle Talon TSi AWD
6 Bolt Swap \ DSMLink V2.5 \ ACT 2100 clutch \ PTE SCM 61 \ Forge MBC@28psi \ VPE O2 Housing \ MR Downpipe \ Thermal R&D Cat-Back \ Tial 38mm WG dumping off O2 \ FMIC w\ in short route \ AFPR setup/walbro 255hp \ PTE 880cc injectors \ Crower Ti retianers \ Crower Springs \ Crower 64414 (stage 3 race) cams \ Ferrea valves \ 3.5 bar MAP \ PLX M-300 Wideband
Old 11-07-2004, 08:45 PM
Yes, I don't have a DSM, like it says in the second line of my post, but i've seen in just about EVERY other car forum that Intake/exhaust are very often the first mods you do to a car, because they are the most inexpensive. If it isn't the first, then it is definitely one of the first mods you should consider. It is a great bang for your buck (speaking from results from other cars, as well as DSMs). If you think my mods are BS, then that's your problem, but if you don't have anything productive to contribute to the post, then don't post.
Old 11-07-2004, 09:00 PM
97_3clipse's Avatar
i would think that a catback would be best before a down pipe..
Old 11-07-2004, 09:11 PM
SSZero's Avatar
Yeah, I agree, a catback exhaust is best as the first mod. Downpipe comes in later...
Stock for now...
Old 11-07-2004, 10:09 PM
AF - Advisor
You really have to do both unless you just want some shyte ricer brand exhaust. If the catback bolts up to the stock cat or downpipe, its to friggin small The exception is one that is 2.5" and barely mates to the stock stuff, then it will work with a 2.5" DP later on. But the best thing to do is get a real exhaust, turbo back, right from the start. An example is a bushur downpipe and bushur catback. Or RRE DP and APex catback. Etc. Do it right, do it once.
Kevin Jewer
Old 11-10-2004, 10:47 AM
spyderturbo007's Avatar
spyderturbo007 spyderturbo007 is offline
I think his first mod, after a tune-up, should be a boost gauge!! But that's just my
1997 Spyder GS-T
5-Speed
EVO III 16g, DSMLink, Walboro 190 lph Fuel Pump, FIC 650cc injectors, CoolingMist 150psi Methanol Injection, Greddy EVO 2 Cat Back, 2.5" Extreme DP, 2.5" Extreme Hi-Flow Cat, Injen intake, HyperDrive C1 Street Disk & PP, HyperDrive Lightweight Flywheel, 1g BOV, RRE UICP, Home Depot MBC, AEM UEGO WBO2, Brembo Slotted rotors, Akebono Ceramic Pads
Old 11-10-2004, 01:00 PM
SSZero's Avatar
GSXRacer brings up a good point... If I get the turboback downpipe/exhaust, then I'll never have to change it, whereas if I just get a catback, eventually I'll have to get the turbo back anyway... Hmmmm.....
Stock for now...
Old 11-18-2004, 01:03 AM
SSZero's Avatar
I have decided: downpipe first. I'll get it custom made at Meineke too...
Stock for now...
