#16
ive got the same problem now, after putting in new header, and H/F cat..
ill change out the oxgen sensor on monday, cuae i used to get those codes, see if that stops the popping on mine too..
1990 DX Hatch 17" 5Zigen Copse Rims CIA, 4-2-1 Header H/F Cat, 5Zigen Exhaust Circle Earth kit B swap in the spring??? ----------------------------- PIX OF MY CAR ![]()
#17
tried changing mine. got one with a connecter and it didnt work, got one without and spliced it, didnt work. took out the connector and it didnt work. im so out of luck right now it pisses me off. i get the bubble back fire and the cel only comes on after i let the engine bog a little. making me mad.
http://www.cardomain.com/id/canabalooza |
#18
Re: I hate o2 sensors!!!!!!!!
Well, for some weird reason, my new one is working now. Must have had to burn off all the old stuff, cause after a couple of days my check engine light stopped coming on.
1991 Sedan LX Auto (Auto2Manual / MPFI / OBD1 conversions complete) www.naytontech.com :: youtube.com/naytontech |
#19
instead of just replacin the sensor you should run the diagnostic tests. The code just tells you what circuit has a out of ordinary reading, not if a sensor has failed.
#20
i know that im bringing up a dead thread but i have been having some problems. i changed my plugs and wires and now it bubbles. the cel only comes on when i decelerate in gear to a lower speed. i can reset the ecu and it works till the cel comes on again. im thinking that my o2 sensor is fine but i dont know maybe not before the plugs i had a quiet bubble now its loud and im loosing huge amounts of gas mileage and it smells like gas when i get out of the car. any ideas? how would i rewire the whole 02 sensor circut. 4g4d maybe you could help me we both live in the boise area.
#21
my accord is doing the same thing. Im going to change my o2 sensor in a few hours need to sleep a little first lol but i hope that fixes the problem if not then i think that its my egr.
Have my rex together one the 28th. Finally. Just my luck they will lose the gaskets and bearings and shipping and ill have to wait even longer. |
#22
also when changing o2 sensors DONT touch the end of the sensor the grease on your fingers will create hot spots on the sensor and cause it to go bad quickly...same concept as a light bulb.
