#16
Re: Brake pedal problem
maybe i'm wrong but i think you could try the 300zx master cylinder.. i'm thinking of upgrading from my stock one cause i already have the 300zx front brakes.. does anybody know if it will work out or what??
http://www.cardomain.com/id/dbo240 ![]() ***LOOKING FOR A COUPE, ENGINE IS NOT AN ISSUE*** |
#17
I thought about getting a 300zx master cylinder and even found a couple on Ebay for cheap but, don't I need the 300zx calipers in order for that to work???
Carm My 1991 240SX SE |
#18
I'm thinking now that I can't get the 300zx master cylinder because my car has ABS. Unless I get one from a 300zx that has ABS. I'm not even sure the 300zx came equipped with ABS. Any thoughts on this???
#19
no i don't think so.. all its doing is putting more pressure through the brake lines.. so if you were going to get the 300zx master cylinder then naturally you'd need better lines, but i have yet to know whether or not the 300zx MC actually fits into the 240.. and if it does then i'll end up getting one soon..
#20
uuhhh wtf? "so if you were going to get the 300zx master cylinder then naturally you'd need better lines" that is bull. ABS means more openings on teh master cilinder. i took the ABS out so i got a non ABS master cilinder. BTW a 300 zx presure plate makes more of a differ then a 300 zx master cilinder. but that is ssssssooooo not neeeded!
i don't know what kined of driving u do, true a 300zx presure plate plus the master cilinder will give u a stronger break feel. but i think changine th epads roter lines and fulid will make u stop quiker and last longer under allot of presuer (down hill tough... etc)
"A good driver is measured not by his lap times, but by the amount of time he spend trying to make sense of his car" E.K. |
