Go Back   Automotive Forums Car Chat > Porsche > 924/944/968
Old 10-28-2004, 10:26 AM
zzpza's Avatar
zzpza zzpza is offline
Re: Re: A question about engine oil changes
Originally Posted by eohrnberger
When I asked the mechanic how to clean out the gunk before switching to Mobile-1, he said that a good procedure would be:
  1. Put 2 quarts of ATF and then fill the rest with some crap motor oil
  2. Drive very gingerly for 5 miles
  3. Drain the old oil out
  4. Replace with Mobile-1 and a new oil filter
I have to admit that I've never heard of such a procedure, but it would appear to make some sense to me. From what I understand, the ATF is a very high detergent oil, and would really clean out the engine's innards. It would also seem to me that a short 5 miles driving gingerly with that mix of stuff in the engine shouldn't damage anything. What do you guys think?
engine flushes are an emotive subject to a lot of people! if you're happy using them and know the repercussions then they are fine.
'02 BMW 330 Ci Sport
'83 Porsche 924 Lux 140bhp
Old 10-28-2004, 10:31 AM
eohrnberger eohrnberger is offline
Send a message via Yahoo to eohrnberger
Umm. What sort of repercussions am I looking at?
Could the flush mixture damage the seals? The bearings? The lifters? The valve guides? The oil pump?
2002 GT Purchased new, Loaded with options Mud Flaps, Michelin HydroEdge, U-Bend Replacement, GMPP Handling Kit, ZZP Strut Tower Brackets
1991 Porsche 944-S2 with 175,000 Miles (and counting)
Old 10-28-2004, 10:48 AM
zzpza's Avatar
a little bit of everything. if an engine's never been flushed before you'll have varnish and gunk all over the internals of the engine. removing it will increase your tolerance's / show up leaks that you didn't know you had / etc.
i'm not against using a flushing agent, you just need to be aware of what they do.
if an engine's got a history of having a flushing agent used on it regularly, then this isn't an issue. but on a 175k mile engine that's never had it done before you never know what's going to happen.
i've never heard of atf being used as a flushing agent though. it might be that atf is milder than the off the shelf flushing agents, and is only being used to make sure you remove all the old mineral oil ready for your nice new mobil-1?
Old 10-28-2004, 10:59 AM
Given this information, I'm inclined not to flush the engine and just put Mobile-1 in with a new filter. If the Mobile-1 is a higher detergent oil, then it'll remove some of the old mineral oil deposits as it goes along. I guess I should figure a quick oil/filter change with Mobile-1 soon thereafter (like 100 miles or something) to get the loosened and filtered deposits out of the engine. Seems to me that switching to Mobile-1 is going to do what the flush would, except perhaps to a lesser extent.
The downside of continuing the regular mineral oil that I can see could be limited oil volume to the various parts of the engine due to deposits in the oil passages. This is not good, as I plan to run the car pretty hard during the local PCA's drivers education events (the reason that I bought the car in the first place).
Is there anyway to test the oil that's in the car right now to determine which oil it is? Syntheic or mineral? This would be a piece of information that would complete the puzzle.
Old 10-28-2004, 11:20 AM
neo the hacker neo the hacker is offline
Thats a bit odd, as i thought ATF as a flushing agent was common in the states, as i have read a few wright ups and they was all from the states and had all said use ATF. I know MERCEDES dealers use it.
Old 10-28-2004, 11:23 AM
zzpza's Avatar
that's the same conclusion i came to for my turbo 944.
as long as you let the car warm up first (remember the oil takes a lot longer to warm up than the water does) you shouldn't have any problems.
i'd do two changes as you suggested. i know it's really hard (escecially if you've only just bought the car) but go easy on it for the first couple of hundred miles after the 1st change, then do an oil and filter change and you can start to enjoy yourself then.
sadly no, i've asked several petrochemists that same question. also there are rules for what makes an oil allowed to be called synthetic, but they aren't as obvious as you would think. merely adding a few of the right sort of additives to a mineral oil will allow you to market it as being synthetic.
Old 10-28-2004, 11:32 AM
zzpza's Avatar
Originally Posted by neo the hacker
Thats a bit odd, as i thought ATF as a flushing agent was common in the states, as i have read a few right ups and they was all from the states and had all said use ATF. I know MERCEDES dealers use it.
it's possible, i'm from the UK automatics aren't as common here so it's easier to get hold of something sold as a flushing agent rather than using something else as a flushing agent.
Old 10-28-2004, 11:33 AM
Well, I'm certainly glad to have hashed with through with all of you. My experience has been that bouncing ideas off of other knowledgeable people generally contributes to the best possible decisions being made (something about the cumulative IQ of the group exceeding any individuals). Thanks for the help.
WRT: Taking it easy, that's not a problem. I'll not be able to get to the track for drivers ed. until May next year. The car goes into storage 12/1, and will come out of storage 4/1, so there's a fair amount of street driving yet to be done!
The first oil change is scheduled for this weekend, and I figure another one shortly before storage, so I'll be able to get all the gunk out properly.
Old 10-28-2004, 12:10 PM
zzpza's Avatar
i'm glad you found any of my info useful.
my turbo is in storage now too. but i still use the 924 as my daily driver.
whilst you have the s2 parked up, i'd recommend starting the engine once a month and letting it run untill it's warmed up. i also give the foot break a bit of excercise to make sure the callipers don't seize. also release and engage the handbrake (emergency brake in the US?) a few times too.
Old 10-28-2004, 12:23 PM
I have a feeling that I'll all right regardless of what I'm going to do. I just checked the maintenance history and noticed that at 165,000 (5/19/2000) the following items were taken care of:
Water Pump Belt, timing belt, Oil Seals
Water Pump Replaced
Timing Belt
Balance Shaft Belt
WP Gasket
Crank Shaft Seal
Crank Shaft Seal bushing
Balance Shaft Seal Kit
Timing Belt Tension Pulley
So it would seem to me that all the important engine seals are still pretty new. I'll bet that I could even do a power engine flush, like at Uncle Ed's, and still be OK as far as the oil leaking is concerned. Just don't want to impact the engine's compression.
WRT storage: I plan on:
  1. Full tank of premium with octane stabilizer
  2. Putting a squirt of engine oil in each cylinder and turning it over a few times to coat the cylinder walls
  3. Putting it up on blocks to unload the tires, but not the suspension (blocks under the suspension so it's not hanging in an unnatural fashion)
  4. Removing the battery
  5. Mothballing the engine compartment (perhaps, it's in a garage)
  6. Covering the exhaust pipe with a can to keep rodents out
  7. Thanks for the hint about the brakes. That's probably a really good idea.
I'm thinking that in the spring I'll unblock it, roll it outside the garage, put the battery back in and fire it up again. It'll smoke a bit until the cylinder oil is burned off, but that shouldn't be much.
Old 10-28-2004, 02:47 PM
930guy 930guy is offline
I think you're f--in' crazy! 944 all ready have a bad rap for loosing rod bearings I wouldn't give it any excuse do it to you. Also remember this is a Porsche not a buick, there shouldn't be any crud in the engine anyway. My 2 cents-a a car with 175K on it you shouldn't be using Mobile 1 anyway. Its only asking for trouble(leaky seals, worn bearing, low pressure). Use a quality brand 20/50 for summer driving and a 10/40 for colder driving.
Old 10-29-2004, 09:45 PM
FabricGATOR FabricGATOR is offline
Send a message via AIM to FabricGATOR
What do you consider a "Quality Brand"?
I'm just curious to know what everybody thinks of me running Castrol GTX 20W50 from Happy's Discount Oil Parts Store.....
Hey! I'm not considered an enthusiast anymore........
2010 Toyota FJ Cruiser Trail Team Edition
2000 Mitsu Montero Sport (Trade In)
1987 944 N/A
1976 Buick Century (SCRAPED)
1979 Yamaha XS1100
I have a parking problem everywhere I go...
2004 Pontiac Gran Prix . . I don't care.
1993 Mustang LX . . . . . I don't care..
1996 Honda Civic CX. . . . . I don't care, well, maybe a just little...
I can't afford to love her anymore!
Old 10-29-2004, 11:07 PM
Well, OK. I could see where a Porsche engine would not build up as much gunk in the oil as say a Detroit engine would.
But I'd still very much want to run Mobile-1 in it, as I will be driving the car hard on the track during the local Porsche club's drivers education events.
Old 10-30-2004, 05:38 AM
zzpza's Avatar
everything you've ever wanted to know about oils...
http://www.xpower-mg.com/Motor_Oil_FA_Questions.htm
my 944 turbo se with ~165k is using fully synth 15w50 mobil 1 with no problems. as long as you stick to the weight recommended in the handbook, you shouldn't have any problems.
Old 10-30-2004, 10:54 AM
My choice of a quality non-synthetic would be valoline/havoline/castrol-I havn't had good luck with penzoil-mobile. If your car always had synthetic oil then stick with it. but if it hasn't you're setting your self up for oil leaks and engine problems. I personally just don't like Mobile 1. I've seen too many engines come through the shop with bad cams, worn out valve train and spun bearings and 90% of them had Mobile 1. I personally use Amsoil senthetic in everything that I own (towing equipment, motorcycles, 930, 944S, But I've used this since they were new. Do the research, check the web sites. If after that you're convinced its the best choice then go for it.
