Old 12-07-2005, 02:03 PM
vinnym86's Avatar
vinnym86 vinnym86 is offline
Send a message via AIM to vinnym86
Re: A cap - is a cap- is a cap ~~ yes/no??!
...heh, 2 yr old thread, dude.
The most beautiful thing we can experience is the mysterious... He to whom this emotion is a stranger, who can no longer pause to wonder and stand to rapt in awe, is as good as dead: his eyes are closed.
Old 12-07-2005, 02:14 PM
Patrick Simmons Patrick Simmons is offline
Send a message via MSN to Patrick Simmons
Re: Re: A cap - is a cap- is a cap ~~ yes/no??!
Whoops, didn't realize how old this was. lmao
Post Whores Wanted
http://www.cyvforums.com
Old 12-07-2005, 02:48 PM
Chevy4life1985's Avatar
Chevy4life1985 Chevy4life1985 is offline
*slaps forehead* newb
Originally Posted by veknyc1 on Sherdog.net
my man, picking up drunk jersey girls is like being employee of the month at mcdonalds
You to read this
http://www.sherdog.net/forums/showth...1&page=1&pp=20
Old 12-07-2005, 02:55 PM
Definately not a n00b in car audio nor forums just didn't look at how old the thread was. sheez!
Post Whores Wanted
Old 12-07-2005, 09:43 PM
PaulD PaulD is offline
Audio Guy
Send a message via AIM to PaulD Send a message via Yahoo to PaulD
the only characteristic you need to look at is ESR ...... if it's much above 2 mOhms (.002 ohms), it will be pretty much useless. That puts all the ones with voltmeters on the top in that category. Sometimes a cap will help because of the way an amp draws power out of the battery, most of the time it won't help.
THIS IS THE MOST IMPORTANT PART ........ it will NOT help a bassboomer system, it's only helpful when playing "real" music.
Old 12-07-2005, 10:00 PM
kcg795 kcg795 is offline
I would get a capacitor for one reason. Basically as a power conditioner. Alternators are not perfect. They mainly give off alternating current and have to be converted to direct current with diodes. Sometimes, the diodes can leak a little bit of alternating current in the system, which can cause a little bit of noise in your stereo system. A capacitor can often help clean up a dirty electrical system and help everything run smoothly. So if I was to get a 1 farad capacitor, I'd be getting to to help everything work better. Not just my stereo system.
Old 12-08-2005, 05:42 AM
I was bustin your balls dude
You to read this
Old 12-08-2005, 10:28 AM
all good!
Post Whores Wanted
Old 12-10-2005, 02:36 PM
Pavlo's Avatar
Pavlo Pavlo is offline
Quick question about caps.
Since I got my 2nd amp my light dim, so i have too much power draw by the amps right? It's not too bad, but I would rather have a cap, then drive around knowing my power is overloaded.
So wanted to ask what is a realtively cheap 1-1.5 farad cap?
VR6> Anything
FWD sucks for understeer? Swaybars do magic.
Old 12-10-2005, 05:21 PM
I would da a big 3 upgrade first, before spending money on a cap.
Post Whores Wanted
Old 12-12-2005, 04:54 PM
Pavlo's Avatar
I have no idea what that is. Whould you please explain?
I think I should start a new thread.
VR6> Anything
Old 12-12-2005, 06:42 PM
1) Battery negative to chassis
2) Alternator to battery positive
3) Chassis to engine
I've only done 1 and 3 so far and it made a big improvement. #1 was just replacing the stock negative wire with a beefier one from Napa. Then #3 went from the Chassis to one of the mounting bolts of the alternator and from that to the intake manifold. I have 4 gauge wiring to do the alternator positive to the battery positive, but need to get an inline fuse first.
Old 12-12-2005, 08:55 PM
CBFryman's Avatar
CBFryman CBFryman is offline
Banned
Send a message via AIM to CBFryman Send a message via Yahoo to CBFryman
An alternator produces only AC, generators produce DC . Caps smooth voltage peaks, nothing more, nothing less.
Old 02-09-2008, 05:33 AM
murd3rd's Avatar
murd3rd murd3rd is offline
Talking Re: A cap - is a cap- is a cap ~~ yes/no??!
hey jsut wanted to add in numeral 1 power caps are the body jewelry of car audio unless you are getting down with a 10 farad cap then it starts making a difference but then you really need to make sure youre charging system can handle the output of that cap with out sustaing a loss of key compents of youre ride. as well people wondering about having 2 caps an 1 shutting down sounds like its wired in sieries in stead of parallel the cap should never turn off if it does it needs to be decharged an rechanrged or its not gunna work properly itll be a volt meter as well i always go with a battery , it will do so much more than a cap ever will check out kenetic they have a battery line called kap killer its super small prob the size of a battery in a kids 4 wheeler an the out put is astronmical its a low input hi output acid free battery an i do believe retail on them is under 200 bucks !!
Old 02-09-2008, 05:36 AM
murd3rd's Avatar
Thumbs up Re: A cap - is a cap- is a cap ~~ yes/no??!
an alternator creats ac an thru a process called rectification its converted into dc
The formula for how much energy a capacitor can store is; (½* C*V^2). Which reads ½ times the capacitance (in Farads) times the voltage squared. As an example let’s find out how much energy is stored in a 1 Farad capacitor that is connected to the +12V system. (½ * 1 Farad * 12 * 12) = 72 Joules or 72 Watt seconds an most of the time a second battery will spare you much headache hope that helps
A YES/NO question thebobs Engineering/ Technical 3 08-30-2002 03:34 PM
Heard GReddy exhaust is best for a 2000 civic si.....yes/no? Evilwayz249 '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 4 08-03-2002 11:29 AM
Straight Pipe Exhuast? Yes\No str8maxn Engine 9 09-14-2001 02:33 PM
Pre Drilled Holes? Yes, No.... wallys99 Audio/Security 2 08-17-2001 03:48 PM
