Go Back   Automotive Forums Car Chat > Dodge > Daytona
Old 10-29-2004, 07:57 AM
4sec0-60 4sec0-60 is offline
Re: 87-90 2.2 turbo II or III WANTED! from A2Z
Hi, oops I forgot the info on the Fiat, 0-60 in 4.0+/-.1sec. 1/4 in the mid to low 10's. 185hp 160tq. 1700lbs. engine put together with 12 to 1 HC Pistons gapless rings. Valve train replaced with all titanium goodies, crank lightened, balanced, along with the flywheel all the pulleys. A Crane Cam Custom grind, Haltech complete ignition! WHOA what a DIFF! Complete Pacesetter exhaust. The body was re-enforced in some places and lightened in others. Finished with a set of 15" teamdynamics Race II wheels @12.8lbs each along with all the Brembo/ Koni/ Custom K&N you can shake a stick at.
Old 10-29-2004, 07:43 PM
PWMAN's Avatar
PWMAN PWMAN is offline
Re: Re: Re: 87-90 2.2 turbo II or III WANTED! from A2Z
Originally Posted by Polygon
I couldn't agree more, except for the comment about the A-568 vs the A-555. Not all A-568s were the same. Later model year A-568s used on the Turbo I weren't as stout as the A-555. The only real difference between the A-555 and a good A-568 is that the 568 has better syncros and a different shift pattern. Those who like a notchier shift will prefer the A-555 over the mushy shift of the A-568. However, that can be cured with a set of "booger" bushings from FWD Performance.
The 568 was NEVER put on T1 cars, only T2-T4 (with the exception of 5 speed turbo minivans). 90-91's received a ''small spline'' 568 which can be conceived as not as strong as 92-up ''big spline'' 568's, but even the 555 was small spline and plenty stout when the Chrome Moly transplate is added. All 568's are stronger than the 555.
The ONLY 5 speed offered in 90-up T1 cars was the A523, same externally to the 568 only it doesn't have forged getrag gears.
88' Dodge Shadow- 2.2L, 5 speed...a couple mods
[email protected] MPH
Old 11-22-2004, 10:11 PM
SVTcobra306's Avatar
SVTcobra306 SVTcobra306 is offline
Originally Posted by 4sec0-60
That info helps alot in my search. I have not chose the vehicle yet but I am looking at the Daytona's due to their reduction possibilities. I have spoke to a few guys about thier car posted for sale. I am definately looking to run it as a super 60(which I'm still learning about) This is all just a hobby of the week type deal. I like to strip them naked and see what I need structurally and dismiss the rest and then start. I have really good friends that have a shop and allow me to mutalate anything till my hearts content and then I pay them to help me put it back together. If you read about the Fiat in my last post you should get an idea. They aren't the most race knowledgable guys but they know engines! Thanks !Jim
Sounds like you'd have fun in a GLH-T or GLHS...
There are better options out there than the S60 package nowadays. Namely custom cals from either FWD-P or TurbosUnleashed, with hybrid turbos.
Yes yes I'm a hippocrit, I have an upgraded S60 turbo, but only because having a smaller turbo will keep me from going too nuts with this car...
1994 SVT Cobra. 306, Ported GT-40X's, Crane 2031, NX Wet Kit (100 shot for now),TKO 500, TwEECer R/T, and all the bolt-ons.....
http://www.cardomain.com/id/mccobra94
1995 F-150 SC/4X4 351W/E4OD, K&N, Custom Exhaust w/Flowmaster.
Freedom Isn't Free.
Old 11-23-2004, 03:28 PM
PWMAN's Avatar
Well, here's how things are most efficient-
Stock T2 garrett turbo-stock-250 WHP
Super 60 w/.63 turbine stage 1 wheel-250-300 WHP
Super 70 w.63 turbine stage 1 wheel- 275-325 WHP
'' '' stage 2 wheel- 300-350 WHP
Hybrid 50 trim TO4E w/.63 turbine stage 2-325-375 WHP
50 trim w/.63 stage 3 wheel- 350-400 WHP
57 trim w.63 stage 3 wheel- 400+ WHP
For example, if your goal is 300 WHP your best bet would be to go with a super 70, or else max out a super 60 but have no extra ''slack'' in case you want more HP later on...and trust me you always will want more.
I have a super 70, swapping to a .63 turbine (stage 1 wheel). I'm adding a ''G'' head, a forward motion TBI header, and 3'' exhaust. Hoping to crack 300 WHP at 22 PSI on pump gas.
As far as the super 60 package, yeah just forget it. It was only meant to be ''off road''. The only things good about the package is the turbo and injectors. Forget the cam and ECU, your car will run like crap. Get a custom cal from turbo's unleashed. I have one, it is awsome. My idle has never been smoother, even with a stock ECU! Can you argue with 22 inches of vacuum at idle??? LOL
Old 12-18-2004, 08:38 AM
wild bill wild bill is offline
I have a 1993 daytona iroc t3 wrecked car for sale with a 5 speed if you are interested 55000 miles on the clock
Old 12-18-2004, 11:21 PM
Vetteman84 Vetteman84 is offline
hey wild bill, what transmission you have in it? i'm looking for the A-555. how much would you want for just the transmission? as a matter of fact, how much for the car, i could use it for parts if you got a good enough price on it.
Old 12-19-2004, 12:04 AM
Everything i read says the a555 was the only trans availablefor t3.Is there another?
Old 12-19-2004, 04:04 AM
probably was, don't know for sure myself, i was just asking cause i know that is the model i want. so, are you wanting to sell?
Old 12-19-2004, 08:16 AM
I really would like to sell whole car,but what is the trans worth to you and i will keep on file if i wind up parting it out
Old 12-19-2004, 11:04 PM
dj_twisted15401 dj_twisted15401 is offline
Send a message via Yahoo to dj_twisted15401
i have a 2.5 T-1 motor and trans out of a wrecked 90 acclaim im selling. it has just a little over 43,000 on the clock. is an auto trans built for the turbo.....i let both got for $500.00...... i have photo if you wanna look.
CAUTION!!!!!!!!! Loose nut behind the wheel!!!!!!! And I don't mean the one that holds it to the car!?!?!?!?!
Old 12-23-2004, 04:36 PM
Polygon's Avatar
Polygon Polygon is offline
The Red Baron
Send a message via MSN to Polygon Send a message via Skype™ to Polygon
No, I don't think the A-555 was used past 1989. I am pretty sure that you have an A-568, which is pretty much an A-555 with better syncros. If your reverse is down and to the right you have an A-568. If reverse is up and to the left you have an A-555.
Old 12-23-2004, 04:45 PM
PWMAN's Avatar
The ONLY trans in the T3 cars was a 568. The 568 is the BEST and strongest tranny.
Old 02-15-2005, 06:55 AM
Smile Re: Re: 87-90 2.2 turbo II or III WANTED! from A2Z
Hey guys, Hmmm what to do? I went ahead and got one of each! An 89 Tona TII/ A555, modded like Gus's suggestion's, and a lightly wrecked in the front 93' IROC R/T- TIII/ A568 with 50Kmls. I definately like the TIII Better! I have the funds to do as I wish, but I'm having issues finding real specs on this setup! I've only found bits here and there? I've checked all the top forums, with no luck on a solid bit of info. anyone know of a book or site that Mopar may have? I have the 4th gen 2.2/2.5 mopar bible but it only cover the TII and before? Well it does give the valve info!?! But what about the block info? What to do with the pistons? rings? Crank? Is all this the same as the TII? I don't believe it is as it is supposed to be stronger Please let me know what you can Thanks, Jim
Old 02-15-2005, 05:55 PM
PWMAN's Avatar
www.thedodgegarage.com is the best source of info.
Old 02-15-2005, 09:48 PM
PWMAN's Avatar
I guess you'd like the T3 better since it has 50 more horses!
Well I'll give you the skinny on the shortblock differences. The forged crank is extremely heavy, 13 pounds heavier than the forged T2 crank. The rods are standard commonblock rods, pistons are unique and forged. The T3 is the only turbo dodge to come with forged pistons. The block is also T3 specific but I cannot remember the differences there.
www.minimopar.net is also a good site.
