| How-To's and Walk-Through's Here's where we show you how it's done! |
#16
Doubleclutching is indeed revving the engine in neutral to sychronize the speeds of the engine and drivetrain portions of the transmission, and isn't necessary in cars with synchros. anyone who has driven a tractor or old truck on the road will be familiar with this process, though
![]() i'm not sure if it's powershifting, or whatever you call it, but Playtoy is correct when he talks about shifting without using the clutch. A lot of semi drivers will do this (drive something for 250k miles, and you get used to shift points) which saves on effort and clutch pads. Basically, you shift at points where you align the engine and drivetrain speeds, and the transmission will slip easily into gear. With practice, you can do it both upshifting and downshifting. Obviously, having a tachometer makes it easy, although you don't need one. You can't do it during hard driving, just easy acceleration or deceleration. I do it a lot on the 3-4 shift, and sometimes if I'm lazy i'll go 2-3-4-5 without clutching.
BD (Before Deer): Clean... Very Clean. AD (After Deer): Nascar Ready. ![]() ![]() Go Baby Go. |
#17
I always thought granny shifting was when you take your sweet time shifting gears o.O
#18
Re: granny shifting and double clutching........
what gives with all this 1st-2nd-3rd-2nd-3rd-4th-3rd-4th-5th shifting crap? this is the second time i have seen someone say that this week it makes NO sense at all!
edit: i just realized it is the same person both times. seriously man, where did you get the idea to shift like that and how have you not broken something yet?
![]() LS1 RX-7 Zoom Zoom |
#19
Re: Re: granny shifting and double clutching........
#20
This is a funny post. I agree with MexSiR on everything except double clutching. I believe double clutching is what you do right after you shift. For instance, you shift into 2nd (any gear) after redline; now, your RPMs are down and you are in a lower hp range of your engine. So, you depress and engage the clutch while holding full throttle, this is an instantaneous action. The rotational inertial your engine built up for that instance helps by lunging your car and creates a momentary void of resistance where your engine doesn’t need to work so hard to bring up the RPMs (closer to peek hp) i.e. for that instance of the lunge . This is a common trick in motocross especially when you find yourself approaching a jump or a hill in the wrong gear. Just adding my 2¢.
http://www.cardomain.com/memberpage/628654 |
#21
![]() .This is double clutching - http://www.felixwong.com/openroad/double_clutch.html & the correct way was posted 5 times already in this thread. |
#22
sounds like a good way to burn up a clutch and not accelerate as fast if you ask me....
#23
thats so retarded, I went to traffic school and when we were trelling our stories this kid sitting next to me was talking about a race he was in and he said he was in 2nd gear and he shifted to 3rd for a couple seconds, slammed it back to 2nd and the put it in 3rd again real quick for a boost. it was so hard not to just laugh in his face right in the middle of traffic school, but every cop in the room knows me and doesnt like me so I just sat there quietly.
current -84 datsun 720 4x4(2nd time)-93 accord-90 camry V6-90 warrior-94 300ex history: -01 R1-04 daytona 600-94 teg RS-95 teg LS -91 teg RS-92 teg GSR-94 civic CX hatch (3 times) -94 civic DX-96 civic HX-97 Accord LX-72 superbeetle -74 beetle-84 silverado-66 c10-74 maverick-78 280z -84 200sx-86 tercel wagon-95 mustang V6 |
#24
...Oh yeah and Im sure "inertial" isn't used properly up there...
"Check that young man for nitrous"
12.428 @ 92.5 Mph Before, Now 12.000 @ 94.1 Mph On 1000ft Track Currently 4th in BHRA All Motor Class...Soon to be 2nd (I hope) ... Theres gonna be alotta slow singin, an flower bringin if I hear my car alarm start ringin ... |
#25
Jeez man i thought no one was gonna get it right! |
#26
Well said, MexSiR.
In racing double clutching is used when downshifting to make the shift smoother. This is really critical when coming into a turn really heavy. If you don't double-clutch it takes a lot of torque to get the engine to speed up to the next gear when you let out the clutch. This torque translates to added braking on the drive wheels. So if your really racing hard, and you are already near the limits of traction, those drive wheels may begin to slip, or equally nasty, they don't slip and the weight of the vehicle is thrown forward putting extra traction on the front wheels and too little on the rear causing oversteer. A "missed shift" is what happens when you fail to make the downshift correctly. When that happens you can't get on the throttle through the turn which implies that you can't get the weight back on the rear wheels making the back end really loose. So bottom line is if you're racing on a course you need to learn to double clutch to be as competitive as possible. But, in normal driving its unnecessary unless you have lame syncros (or no syncros like old trucks). |
#27
Re: Re: Re: granny shifting and double clutching........
Good link posted by Jackassi. It brought up the point I glossed over that while double clutching in racing, we are braking at the same time. A lot of modern cars suck for this because they mouth the gas pedal lower than the brake pedal. You can get modified pedals for a lot of cars to enable better "heel-toe'ing".
#28
True I've tried heel-toeing in my civic and I can't seem to be able to touch both at the same time. The gas pedal is too low.
#29
shit, i hit both by ACCIDENT sometimes >_<
having big feet sucks, but it's easy to heel-toe shift.
#30
As long as your controlling the brake & gas with one foot it's considered heel-toe but in reality it's impossible to do in most cars. Bascially you use your big toe on the brake and the right side of your foot to control the gas. The pedals are purposely posistioned that way for a safety feature so people don't slam on the gas instead of the brake or visa versa. Now if your real good you left foot brake. That means left foot brake & right foot gas. But you may ask what about the clutch, that's the whole point your not using the clutch what so ever. Heel-toe and left foot braking are racing techniques, if you do it on the street don't wonder why stuff breaks. |
