Old 10-14-2004, 07:21 PM
johnny2quick johnny2quick is offline
Re: Re: turbo intake explained?
Originally Posted by BoostedSpyder
that would be a MAF, not a MAS.
the MAF is mounted behind the BOV and has the ability to meter massive flows of air, compressed with a 'hot wire'. the wire is hot and based on the amount of air needed to 'carry' off heat, it can calculate airflow.
placing the MAS in that spot would disrupt the airflow so much that it would be like stuffing the pipe with cotton.
AFR would be calculated on what the ECU sees from the air metering source.
a MAF is less restrictive, so theoreticaly you can pull more air = more HP.
i have been finding out that you can hack the 2g MAF to death practiacaly, and compensate with the SAFC [or any fuel tuning/logging setup], so my MAF thoughts were squished.
i was basically asking what are the effects of venting (i didn't think about that thread till after i made the post here).
MAFS = Mass air flow sensor, same as your "MAF", only with "S" on the end
Old 10-14-2004, 07:36 PM
BoostedSpyder's Avatar
BoostedSpyder BoostedSpyder is offline
Send a message via MSN to BoostedSpyder Send a message via Yahoo to BoostedSpyder
i htink ou are confusing yourself. i have never heard of a MAFS, it is either MAF [hotwire] or MAS [honeycomb]
do a search on MAF and MAFt. you will learn more.
by venting you are releasing air from a closed system. closed being that all the air in it has been metered. thus, when you shift you will be in an induced rich situation and will cause backfires when you shift. also you may run into problems at idle, it will not hold idle and will stall in between shifts.
i was able to run it vented after a bunch of basics, intake, full 3'' exhaust w/no cat, 25 fuel pump, boost controler, and a couple other littler ones. some guy's still have problems with idle and i had some pretty large backfires occaisionaly [fire in the night... lol]
Old 10-15-2004, 07:27 AM
at newcelica.org, some call it a MAFS, that's where i got acronym, but that doesn't matter. i know i wasn't clear on my last post. what i meant was, if i vent the system properly, meaning with the GM MAF and translator, what would the effects be on the engine, HP, and torque? and would this setup be better then the stock setup?
Old 10-15-2004, 07:42 AM
spyderturbo007's Avatar
spyderturbo007 spyderturbo007 is offline
As far as I know there is no difference (someone correct me if I'm wrong). The only thing is that you can vent your BOV, which makes it MUCH louder.
1997 Spyder GS-T
5-Speed
EVO III 16g, DSMLink, Walboro 190 lph Fuel Pump, FIC 650cc injectors, CoolingMist 150psi Methanol Injection, Greddy EVO 2 Cat Back, 2.5" Extreme DP, 2.5" Extreme Hi-Flow Cat, Injen intake, HyperDrive C1 Street Disk & PP, HyperDrive Lightweight Flywheel, 1g BOV, RRE UICP, Home Depot MBC, AEM UEGO WBO2, Brembo Slotted rotors, Akebono Ceramic Pads
Old 10-15-2004, 11:02 AM
96spyderman's Avatar
96spyderman 96spyderman is offline
Send a message via AIM to 96spyderman Send a message via MSN to 96spyderman
If doing all that doesn't really do much other than make it louder......sounds like something to do if your bored.....and want it louder
"A man's greatest work is to break his enemies, to drive them before him, to take from them all the things that have been theirs." -Ghengis Khan
