Go Back   Automotive Forums Car Chat > Racing > Drag Racing
Old 10-13-2004, 09:44 PM
chevytrucks92's Avatar
chevytrucks92 chevytrucks92 is offline
Re: Slicks vs. DOT Slicks vs. Street Tires.
Yeah. Had to replace bearings in two different engines. Had one block to crack. Just a bad deal! Its doing good now though (knock on wood).
**1966 Chevy II**
355 SBC, Turbo 400, 5.13 gear, IHRA Certified to 8.50 in the 1/4
Last Race (10-6-07) So its been awhile...
Dial: 6.77, RT: -.0001, 60': 1.4360, 1/8th: 6.7942 @ 100.65 mph
Fastest Pass of '07 (10-6-07)
60': 1.4360, 330': 4.3453, 1/8th: 6.7942 @ 100.65 mph
25 and in BIG TIME Debt Crew member #2
Deuce's Wild Racing: Take a Ride on the WILD SIDE
Old 10-19-2004, 04:35 PM
86MonteSS 86MonteSS is offline
a smaller than stock tire ,slick will pick you up at the track giving you more take off but less top end which you dont really need in the 1/4
Without a Turbo imports are nothin but a pissed off bubble bee.
Old 10-25-2004, 07:02 PM
lowsonoma1999's Avatar
lowsonoma1999 lowsonoma1999 is offline
Authorized Vendor
Send a message via AIM to lowsonoma1999
Re: Re: Slicks vs. DOT Slicks vs. Street Tires.
A little off topic
You've had better luck then we've had the past 2 years. '69 Camaro, 496ci bb, powerglide.
2003: 1) transmission didn't shift, broke top off 1 valve, had both heads rebuilt. 2) oil pickup screen fell off during a pass, ate up some bearings and the crank 3) shop that rebuilt the heads put the wrong rockers on, couple of the rockers were hitting the valve spring retainers, eventually breaking a couple valves, leading to holes in 2 pistons, and had to sleeve two cylinders ( this is the first time we haven't built the motor ourselves, and all this happens, I guess if you want it done right, do it yourself) 4) 2 torque converters (cut open one and the fins of the converter were pretty much all melted together) 5) when one of the converters went, contaminated the transmission enough to warranty a rebuild
2004: 1) Eagle H beam rod broke into pieces and went through both sides of the oil pan, also destroying the crank, cracking the block, bending another rod, and destroying 1 head pics here -> http://www.agbulletracing.com/uhoh.htm Last time we let that guy touch our motors. Have a different engine builder now. 2) 4 torque converters in all this season. (while running super gas, kept breaking the sprague in the converter, of course Coan didn't tell us that the spragues used in their converters were inferior and not really made to run super gas. put a solid sprague in from ATI, all problems fixed now. 3) 1 torque converter contaminated the trans enough to warranty another rebuild 4) 1st time trial running super gas at US Nationals, with new tires, axle stripped out the spool in the rear end. Discovered that the company that rebuilt our rearend 2 years ago put the axles in backwards, and the drivers side I think, was only in the spool about a 1/2" How it lasted 2 years, I don't know. But the new tires that were put on for US Nats was just too much for it and it stripped it out. 5) Water pump went out 6) Been fighting bogging problems at the line when going up on stall for 2 years now. Was referred to a guy at US Nats to talk to. I can't remember his name right now, but discovered that the carb that we thought was a 1050cfm, was actually a 1150. Too big for our motor. $1100 later, we have a Holley 1050, built by this guy in Kansas. Half of the super gas cars out there run his carbs, highly recommend him if I could remember his name. 7) Lastly, 1 alternator
Probably all in all about $12k spent this year in repairs, plus a lot of time. So, now a new engine with no problems, a torque converter that will actually handle the power we are putting out, new rearend, new tires. My dad got 2nd place at the Fall Classic last weekend at IRP in Super Street. Anyways, go to www.agbulletracing.com for pics, videos, etc. . .from our race team.
JJ
Old 10-25-2004, 10:01 PM
That sucks man, lol. We haven't had it that bad the past two years, but we have had it pretty rough!
Last season we had troulbe with 2 different set of heads, and both of them were due to the shop that did them. We let the same person do both set of heads (1 set of allum. Dart II, 2.05, 1.60 valves, and 1 set of cast iron Dart II, 2.08, 1.60 valves) and the guy put non-roller springs in both of them. Of course we had trouble with sticking valves, luckily, no pistons were damaged.
Ok, took them both sets to a new shop, and the guy done hte heads, done a great job and we had no trouble the rest of the season (al though this problem lasted nearly half that season, it started out as bent push rods, then rocker arms coming off).
This year, we have had terrible luck with our engines (built by the same shop that done the heads, and like you, thsi was the first time anyone put together an engine for us). Ok, the first one must have had a bad set of bearings (not the shop's fault, just faulty products) because the engine was going down before what actually happened to finish it off, lol. I mean every week, it would start out in the low 4.30s (330 ft.) and wind up in the low 4.40s by the end of the night. So it was getting ready to seize up. Ok, in the finals one night, the oil filter came unscrewed, and allowed nearly 4.5 quarts of oil to come out (we only had a 5 quart pan at the time). The engine lost its oil pressure during the week when we were loading it back up (after finding the problem, changing oil, and going wiht anothe rfilter).
2nd engine (the guy made the first one up for us, BTW, all of these engines are/were 406 SBCs). The guy built it, no charge, but failed to tell us tha the internally balanced it (like you normally do a 355) so we put our 400 balancer and flywheel on the engine (had it way way way out of balance) and it spun every main bearing in it, and cracked the block in the lifter valley (we didnt know it had done htis however at the time). The guy replaced it again, no charge (he is really good about backing his stuff), had to replace all bearings and a crank (forged steel, so a pretty big price).
Now, 2nd engine still, on its 2nd overall, took it to the track, immediatly had water in the oil. Engine ran fine however (low to mid 4.30s). Found an intake leak (not tightned all the way on the back drivers side), thoguht we had cured the problem. Next weekend, still had water in the oil, so we assumed it was jus tleft over. Change oil and filter during the week, go back to the track the next weekend, and after one run, the oil is back to milky white, and the car had developped a miss. Take it back to the shop, he discovers the cracked block. So he offers us a deal. He gives us a complete short block of another 406 (flat top engine, freshly overhauled, had previously been ran in some kind of dirt track car, i thikn a limited late model, but may have been a modified) and sold us a set of cast iron Dart Pro 1 heads, that had the chambers filled in smooth (to make up for hte flat top pistons). I think those costed us around $2k, and that is hte engine that is currently in the car (runs low 4.40s when the track is right, with new slicks it woudl be in the mid 4.30s probably, which is about a tenth slower then the other engine-which we now have back on a stand-)
so finally, we have a good engine, that doesn't have any leaks, any knocks, holds good oil pressure (idles on 80 pound, revs to about 95) and has been run problem free (knock on wood!) for the past 3 months, lol.
Its really discouraging when you go over to the track, and only get to run one or two time trials, and then have to load the car up, due to a miss, lost oil pressure, or water in the oil!
**1966 Chevy II**
Old 10-25-2004, 10:17 PM
Those are cool videos by the way. I dont think my car woudl be taht fast (pretty sure it wouldn't, it may do 10.20s, but not 9.20s), lol, but it brings the wheels up (especially the left one) as high as your car does, and by just watching the vids, thats about how it looks going down the track from inside, lol.
I doubt it could go the 1/4 mile, its cranking 6000 rpms in 330 ft. (406 SBC, powerglyde, .513 gear), and the last time at a 1/8th (i wasn't driving it then) it turned 7k at the lights.
What are your 60, 330, and 1/8th times if you don't care to give?
The car I drive would probably do low 6.70s or high 6.60s in the 1/8th (I've never driven in an 1/8th, and the last time when car went through an 1/8th it had a 355 engine-a very strong 355-, and ran 6.71 @ 101 mph)
**1966 Chevy II**
Old 11-21-2004, 08:46 AM
Zgringo Zgringo is offline
On my street legal car I get 8-10,000 miles without much hard draging, but never over 1 year use.
On my Pro Import 18-20 runs on GoodYear drag slicks, about 6 months
