Go Back   Automotive Forums .com Car Chat > Jeep > Grand Cherokee | Grand Cherokee SRT8
Old 10-06-2004, 09:06 PM   #16
msrjeep
Send a message via AIM to msrjeep
Re: Transmission
you have the 6 cylinder, yes?
msrjeep is offline   Reply With Quote
Old 10-07-2004, 08:51 AM   #17
SAEAPP
I had a similar issue with my '01 GC (shifting oddly when I came to a stop, and an occasional odd shift while driving in lower speeds, and starting out sluggish). I took it to Jeep and they ran diagnostics, turns out it was a bad Governor Solenoid and Pressure Transducer. Jeep quoted 495 plus tax (included labor at 85/hr). I took it to another tranny repair shop and had it down for $426.
SAEAPP is offline   Reply With Quote
Old 10-09-2004, 04:32 PM   #18
Big Bad
Re: Transmission
I got a quote at a tranny shop, for the same thing, governor solenoid and pressure transducer, for about $300 canadian with labour. Im not sure if this is aftermarket stuff, because when I visited a Jeep dealership, $310 canadian without labour, but with original parts.. I just want to know if you got the aftermarket parts, and how's it performing so far.
Big Bad is offline   Reply With Quote
Old 10-10-2004, 03:00 PM   #19
msrjeep
Re: Transmission
for $10 i would get it done at the dealership with OEM
Old 10-10-2004, 04:29 PM   #20
JHEA215
Re: Transmission
Did anyone determine why the Jeep Overdrive (O/D) light stays on and will not go off? Mine is a 1995 Grand Cherokee with 4.0 Liter
JHEA215 is offline   Reply With Quote
Old 10-11-2004, 10:30 AM   #21
SAEAPP
Re: Re: Transmission
I got the work done on 9/23/04 and they used OEM parts. I was there when the guy delivered them from Jeep. The tranny shop I went to said that for electrical parts they use only OEM parts. And, knock on wood, but everything is running great now.
Old 10-11-2004, 10:31 AM   #22
SAEAPP
And of course the the labor was $20 cheaper/hour, so that was where a lot of the cost savings was at.
Old 10-11-2004, 05:50 PM   #23
Big Bad
Re: Re: Re: Transmission
Thanks Bud... I will go with the OEM...
Old 02-29-2012, 03:23 PM   #24
patrick patrick
Re: Transmission
Originally Posted by dksob81 View Post
yea it could be the CM (transmission comtrol Module). have u had the tranny fluid and filter changed this might help.
solenoid and pesure transducer were replaced and still in and out of limp mode. od light on=limp. od lgt off=normal
patrick patrick is offline   Reply With Quote
