#16
Re: Re: A/C Compressor clutch doesn't engage
To force the compressor to run to charge it up, you simply jump out the low-pressure switch. But ONLY force it to run as you are charging it up, as running it while low on refrigerant will burn up the compressor.
#18
Re: Re: Re: A/C Compressor clutch doesn't engage
Are you sure the A/C system is low on freon? Have you checked if the Compressor Clutch engages? I ask because if you have a bad pressure switch (either on the high or on the low sides) on the system the compressor clutch won't engage for anything. My car is a 1991 3.1L V6 and has a continous running compressor with just one transducer (Pressure) switch on the high side. What I did was, with the engine OFF, I jumped the A/C compressor clutch by running a length of wire straight from the battery into the clutch connector at the compressor. Mine is accessible for under the car, I'm not sure about yours. It should engage right away when you power it, if it doesn't the clutch is bad. Now you can crank the engine and leave the clutch hotwired so you can add freon to the system |
#20
Re: Re: Re: Re: A/C Compressor clutch doesn't engage
Found the problem, did not have the charge hose to the freon can, tight enough to depress the valve in the can tap, got it to charge, btw, there is a relay that can be jumpered to make the compresser run bad news, it appears to have a leak, haven't found it yet, no oil around compresser, etc, appears to be a fairly substantial one. a week ago everything looked good, this week, no pressure. Thanks to all that replied, it was appreciated. |
#21
Well, you need to find the leak ASAP, while it still has pressure. If its leaking that fast, it shouldnt be hard to find. Check the connections on the high-pressure side, as they are much more prone to leak. Look for oily areas around every connection, and it may help to use some liquid leak detector or some dishwashing liquid diluted with water. Hope this helps.
