Old 10-02-2004, 10:35 PM
nerve_agent nerve_agent is offline
whatever ,obviously no helpful people in this forum, I'm looking for answers not flak.
Old 10-02-2004, 10:39 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Re: 2000 Blazer owner in need of help!!
Originally Posted by nerve_agent
I bought this thing in May of 2003 and already have had to put almost $6000 worth of repairs into it, let me just list them for you.
right motor mount,fuel pump,plugs and wires,3 O2 heater sensors,drivers side window motor,6 tires,upper and lower ball joints,idler arm,catalytic convertor,battery,O2 sensor ground wire,4wd actuator motor,fuses,2 alignments and 6 bottles of tylenol for myself.
Even after all of that my coolant system has a vapor leak now, the idler arm is bad again, it shakes like crazy at any speed over 45 and every bump I hit is like hitting a 2 foot deep pothole, really rough stuff. If anyone has any suggestions, comments or ideas to help with this it would be GREATLY appreciated
read what you have replaced above.
I think you a little shell shocked.
Old 10-02-2004, 10:49 PM
not shell shocked at all. simply want to resolve this so it isnt a problem anymore and I can move on to other matters, not to mention I want to find answers not " I dont know" or "thats just how a Blazer rides" or whatever excuse or half-assed answer that can be thrown my way. Looking for a solution to the problem not just forget its there and go on with life.
Old 10-03-2004, 10:56 AM
Mikado14 Mikado14 is offline
By your description, you said there is a side to side shimmy.
Here's a thought and it won't cost you a dime and is sometimes overlooked.
If one tire or more has a belt seperation, it will create a high spot on the tread. As the wheel rotates and the high spot is in contact with the ground, it raises the height of the vehicle and then as it continues to rotate the height then goes down.
I am sure you can see how this can cause the side to side shimmy. Jack each wheel up and rotate it and feel the tread as it is rotating.
If you lived close by, I would be more than happy to have you bring it on a weekend to my shop and check it over for I sympathize with your situation. Your between a rock and a hard place, been there myself.
Old 10-03-2004, 07:20 PM
finnaly someone who isnt so critical of others. I have done alot of reaserch over the past few days and the one thing that I am told the most is tires. Ya they may be new but that doesn't matter. It was freezing this morning so I checked the tire pressure ( cold psi) and found my fronts at 20/22 and rears at 28/30. so i went and filled all to 35. ride smotthed out a noticable difference but the full body shake and bump/crack vibration still hard. the vibration grows as speed increases and it goes thru dash,doors,side view mirrors, and under my seat. now it sometimes pulses which after confering with a few more knowledgable friends of mine they said more than one tire could be bad, suggested rotating front to back and see if the vibrations change/move and then go from there narrowing down what it could possibly be. As far as living closer, WI is a long ways from PA but I really do appreciate the generous offer.
Old 01-05-2005, 12:29 PM
canro canro is offline
Just my 2 cents. Have you checked your tires? Sounds like a busted steel belt.
Old 01-05-2005, 01:01 PM
Ramblin Fever Ramblin Fever is offline
Totally agree, this is what it sounds like. Went through this myself a year ago; had truck checked out by everyone, and everyone kept saying the tires were at fault. I didn't believe that however, cuz the Goodyear Wrangler RT/S tires only had 35K miles and had plenty of tread left.
Changed tires out, truck rides great. End result, I will NEVER go back to a Goodyear tire, 2 1/2yrs old, 35K miles and very well taken care of - and that's what I get.
1997 3.2L V6 Rodeo
32" Yoko's, 16x8 MB Wheels, 2" lift, Brushguard, KC Fog's, Loadwarrior Rack
On it's way to 185k strong
2004 3.4L Tacoma TRD off-road 4x4 Double cab
32" Yoko's, Westin Bull-bar, KC Fogs 60K miles
