Go Back   Automotive Forums Car Chat > Nissan > Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail
Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail Nissans greatest 4WDs and SUVs
Old 07-02-2001, 11:46 AM
Schludwiller's Avatar
Schludwiller Schludwiller is offline
XTerra Guy
Add me to the list.
I noticed mine had settled a bit last week. I adjusted them up about 1/2" and everything is fine again.
Old 07-02-2001, 01:21 PM
xterrabull xterrabull is offline
Originally posted by Philosopher
Not that anyone cares, but my torsion bars DID NOT sag at all ... the air pressure in my front tires was WAY down ... like down to 20 - 22 psi. So I aired back up and bing, everything is back to normal. Duh.
I thought that in that measurement exchange w/Ian on XOC a couple weeks ago you mentioned the space between the bumpstop and upper A-arm was ~1" which might have indicated a t-bar sag. I have almost 1/2" of spacing here & I thought my t-bar lift was only 3/4-1".
Old 07-02-2001, 01:53 PM
Philosopher's Avatar
Philosopher Philosopher is offline
I may not be reading this correctly, but the space between my upper A-arm and the bump stop right under it is about 3/4" which is what it has been since I installed the torsion bars ... Ian on the other hand says he has about 1" in that space. But he hasn't answered 90% of my other questions involving measurements ... of course, then again no one else has either so ... :o
Old 07-02-2001, 02:19 PM
Yes, you're reading it correctly. Funny, my t-bar lift can't be that much 'cause my 31x10.5's rub the Canadian mud flaps (I've shaved them with a knife to aid clearance, too) when I back out of the driveway & turn wheels simultaneously but I don't have too much space between bump stop & upper A-arm. Another funny thing: driver's side camber can be adjusted to dead center of spec (range is .1-1.1 with .6 the target) but passenger side can only be adjusted to about .2; but, all my measurements show that the passenger side t-bar is cranked LESS than the driver's side--that is, most passenger side measurements are about 1/16-1/8" shorter than driver's side. The only thing I can think of is we're seeing car to car and intra-car manufacturing tolerances rearing they'r ugly heads. I took some measurements but I've been hesitant to post 'cause they're on the driveway w/31x10.5" tires so the relevancy is not huge but I'll try to post tonight. Actually, I'll re-measure & post 'cause I recently had my tires rotated & the tread thickness difference was pretty big.
Old 08-05-2001, 01:29 PM
Thor Thor is offline
Thumbs up Sway away measurements.
I just installed the sway away torsion bars this weekend. I also found that the passenger side adjusting bolt required fewer turns than the drivers side adjusting bolt. As it stands now the drivers side was turned 17 full turns and the passenger side was turned 15 full turns. I get 12" on both sides from the ground to the frame, 17" from the hub to the lower wheel well, and 1" between the A arm and bump stop. I am still running stock AT's with 35 psi up front and 33 psi in the back. I also noticed when I took the tires off that my passenger side tire has much more wear on the outer edge of the tread and the truck has always pulled slightly to the passenger side. Any feedback on the ride height? To high or push it more?
Old 08-05-2001, 06:38 PM
Synchro Synchro is offline
Send a message via ICQ to Synchro Send a message via Yahoo to Synchro
if the tire has much more wear on the outside than you definitely have an alignment problem that needs to be looked at before it gets really serious. as for the height and turns issue, this could be as simple as you having the bars indexed differently. the number of turns would depend on if you had exactly the same angle of the rear anchors when you reinstalled them. i wouldn't worry about that too much, it is more that the 2 sides are even to the frame that is the area you want to look at. if they are equal you are fine.
