Closed Thread Show Printable Version Show Printable Version | Subscription Subscribe to this Thread
Old 09-20-2004, 11:14 PM
89IROC&RS's Avatar
89IROC&RS 89IROC&RS is offline
Re: What is a good gear Ratio for me?
well, im away from my literature right now, so ill back down on this one
i do know the 10 bolt for third and fourth gen cars are interchangeable, at least on the inside. the Borg Warner rear on the other hand is a 7.75in ring gear, and i thought was used in the 5.7L IROCs. maybe im wrong on this one, im not exactly in a great frame of mind right now, yall will have to be patient with me.
Chevrolet Camaro - I enjoy beating the hell out of people
http://www.automotiveforums.com/vbulletin/showthread.php?t=68052
  #17
Old 09-21-2004, 12:18 AM
ridge_runner ridge_runner is offline
Send a message via AIM to ridge_runner Send a message via MSN to ridge_runner
the inside isnt... the diff on the 3rd gens are 26 spline the 4th gens are 28
  #18
Old 09-21-2004, 12:20 AM
well 86 and prior is diff. i believe.. or 87 i 4got when they converted to 28
  #19
Old 09-21-2004, 12:31 AM
kenwood guy's Avatar
kenwood guy kenwood guy is offline
Send a message via Yahoo to kenwood guy
Re: Re: What is a good gear Ratio for me?
Originally Posted by FormulaLT1
Well there are 3 type's of Posi units
1. Locker- which supply's 100 % of equal power to both wheels at same time unless your turn which will cause the outside wheel to continue turning while the inside wheel will be unlocked.
are they also called "detroit lockers" and I also hear that they make alot of noise when turning true??? and does anyone have them on there car???
Simon R
2001 Silverado W/T 4.3
124,000
  #20
Old 09-21-2004, 12:33 AM
FormulaLT1's Avatar
FormulaLT1 FormulaLT1 is offline
Fight the powwa!!!
Send a message via AIM to FormulaLT1 Send a message via MSN to FormulaLT1 Send a message via Yahoo to FormulaLT1
Mid way through the year in 88 they converted to 28 spline. However after 88 You actually would still find some but not many 26 spline axles used on rear drum brake equiped cars
RIP Hypsi - I just want to express I will never be the same after having lost such a good friend. You meant alot to me and I feel I am a better person for having known you. Til the day we meet again my friend you will always be in my heart.
Mods: Weight reduction (I don't wear underwear)
  #21
Old 09-21-2004, 12:37 AM
FormulaLT1's Avatar
Fight the powwa!!!
Re: Re: Re: What is a good gear Ratio for me?
I have a Auburn Pro Locker which isn't exactly like the Detroit locker but same idea. and yes under hard turns with heavy throttle it makes a ratcheting sound but under coasting conditions you can barely hear it
  #22
Old 09-21-2004, 12:41 AM
Re: Re: Re: Re: What is a good gear Ratio for me?
"ratcheting sound" I thought it would be a cool sound like a flowmaster or blow off valve
Simon R
124,000
  #23
Old 09-21-2004, 12:45 AM
FormulaLT1's Avatar
Fight the powwa!!!
No the Auburn series unit uses clutch packs to lock the axles in place so you get a ratcheting sound other units might make another sound though. Some use bearing's so I'm not sure what they sound like
  #24
Old 09-21-2004, 07:24 AM
LT1MAN LT1MAN is offline
Banned
so you guys telling me that 3:73's are a happy medium?
  #25
Old 09-21-2004, 11:06 AM
FormulaLT1's Avatar
Fight the powwa!!!
Yes 3.73's are a good all around gear for a Auto and If you have a stick you can even go upto 4.10's without causing any major problems
  #26
Old 09-21-2004, 05:09 PM
yea go with the 3:73s
  #27
Old 09-21-2004, 07:37 PM
89IROC&RS's Avatar
personally, if its a highway car, i dont recomend more than 3.42 or 3.45, depending on your rear, 10 bolt vs 9 bolt. if its gonna be a weekend play thing, then 3.73;s are fun, drag car, 4.10's
  #28
Old 09-21-2004, 11:16 PM
would that go for all gen camaros????
Simon R
124,000
  #29
Old 09-21-2004, 11:27 PM
Genopsyde's Avatar
Genopsyde Genopsyde is offline
The President
Send a message via AIM to Genopsyde Send a message via Yahoo to Genopsyde
now what's the deal with 2 and 3 series carriers? can someone explain that in simple words.
Old 09-21-2004, 11:50 PM
FormulaLT1's Avatar
Fight the powwa!!!
2 series units are for use with 2.73 -3.08 gears and have a thinner seat and place the gears farther away from the pinion because the pinion gear is wider. 3 series units are 3.23 and up place the ring gear closer to the pinion gear. Richmond and Strange make gears with 3.23 and higher ratio's that will work with 2 series units though
Closed Thread
