Old 09-21-2004, 11:14 AM
calamari925's Avatar
calamari925 calamari925 is offline
Send a message via AIM to calamari925
Re: Fuse Keeps Blowing Under Hood By Battery
i will try it i hope it works..... thanks for all the help
Old 09-21-2004, 04:06 PM
well i did that and now it still don't work i know there is power going through the wire end to end but there has got to be a easier way than fallowing it from one end to another no one thinks that the fuse holder may be bad?
Old 09-21-2004, 05:30 PM
Haibane's Avatar
Haibane Haibane is offline
Send a message via AIM to Haibane
no fuseholder shouldn't be bad... Get a voltmeter find the problem
www.cloudcity.deviantart.com
Old 09-22-2004, 10:34 AM
and once i get that how do i know if i found the problem i never used a volt meter before??
Old 09-22-2004, 11:08 AM
Haibane's Avatar
well test at the batter the amount of voltage. then test the power...
Old 09-22-2004, 11:31 AM
so test how many volts are coming from the battery it self then test how many volts are going to the other end of the power wire?
Old 09-22-2004, 12:04 PM
Haibane's Avatar
You got it
