Old 09-17-2004, 10:05 AM
1PhatCX's Avatar
1PhatCX 1PhatCX is offline
Re: Re: turbo question
Originally Posted by 91civicDXdude
If you notice, they stopped selling the manifold because it was fucking trash. OBX does have a new one out though that is a direct copy of full race's manifold which looks promising, and sells for $400.
the SSauto manifold had runners that were too small, too thin, had bad welds, and placed the turbo too low for any practical use.
alright, thanx for that info
also, what kinda fuel management would i be looking at if i'm gonna be running 7 Psi on a tiny T3 turbo?
Old 09-17-2004, 01:48 PM
91civicDXdude's Avatar
Re: turbo question
I would recommend a chipped ECU and turboedit, or convert to OBD1 and run uberdata, crome or others along with using 450cc injectors.
In the very least i would use the AFC hack which i did use for a couple months with good results, just make sure to retard your timing at the distributor a couple degrees (no MSD timign retard is needed and i'll explain why if you really want to know).
If you really just dont want to have proper management and want to boost, you could always throw on an FMU and upgraded fuel pump, but i do not recommend an FMu for any application.
Old 09-17-2004, 01:55 PM
1PhatCX's Avatar
alright, well how exactly can u do the AFC Hack? and should i used 450cc injectors as well with the AFC or use stock ones?
Old 09-17-2004, 09:05 PM
Kunundrum's Avatar
Kunundrum Kunundrum is offline
Send a message via ICQ to Kunundrum Send a message via MSN to Kunundrum
Crew the AFC hack use good old checkvalves.
I have a Turbo Chip and a vafc and still got a Map sensor error when I had the turbo. it went away with checkvalves.
and for your fuel use a 10:1 or 12:1 FMU. cheap and Simple.
2012 VW Golf 3 Door Automatic (Company Car)
2011 VW Golf Wagon 5 speed (Company Car)
2010 VW Jetta 2.5 Automatic (Company Car)
2009 VW City Jetta 5 Speed (Company Car)
2009 VW GLI 6 Speed (Company Car)
2008 VW Jetta 2.0T 6speed (Company Car)
1999.5 Audi A4 Quattro Sport 1.8t (Chipped 1.0 bar) Sold
1990 CRX Si (Built B17a) - Stripped and Crushed
1988 CRX Si -- Stolen
1990 Civic Cx -- Sold
1990 Civic Si -- Parted
1989 Civic dx -- Sold
Old 09-17-2004, 09:13 PM
Kunundrum's Avatar
Re: turbo question
as for the manifolds I'm not going to start a pissing contest. but I have seen the OBX ones break a hell of alot more than the SS ones, the main reason is that people don't put a fexible part before the cat. the Main reasons the Manifolds break is because they have no flex.
Old 09-17-2004, 10:50 PM
Re: turbo question
The AFC hack has its ups and downs but it is guaranteed. I used it as a fail safe if one of my tunes didnt turn out right.
there is also no need for check valves unless you are running an FMU, especially if you are running an AFC hack. NO CHECK VALVES WITH AFC HACK
You shouldn't get a check engine light if you have a boost room unless the rom is bad. the stock map sensor can read in excess of 12psi, its the ECU that determines that 1.3 psi is error and triggers the check engine light. A boost rom will have this "check" disabled and allow the map sensor to input values above 0 vacuum and provide mapping to do so.
1PhatCX: 450cc DSM injectors are crucial to using the AFC hack. other larger injectors can be used too on a different scale, but 450's have been proven to work for upwards of 10psi.
Basically, the AFC listens for the voltage output of the MAP sensor, and by the user subtracting fuel, it adjusts the map sensors voltage output on a scale which the stock ECU can still read. thats how an AFC works.. modifying map sensor voltage. So if we know the ECU will throw a check engine light for MAP sensor if it reads roughly 3.1 volts, or 1.3psi, and the map sensor reads 0-5 volts on a scale from about 25in/hg of vacuum reading 0 volts, up to 14.7psi reading 5 volts, you want to scale your map sensors voltage so that when it is actually reading your maximum boost pressureit is only putting out less than 1.3 volts, so the ECu stays happy. Well in all this, you are setting your fuel controller to subract 30-40% fuel from your maps, so you will need fuel injectors 30-40% bigger than the stock injectors, i.e. 450cc injectors.
so once again, in order that i prefer..
Fuel managment for turbo:
1. standalone or chipped ECU with 450cc injectors or larger
2. AFC with 450cc injectors
3. small mexican under the hood spraying extra fuel from a squirt bottle with one hand and retarding the distributor with the other hand while driving
4. FMU & check valves with optional MSD BTM
