Go Back   Automotive Forums Car Chat > Nissan > Sentra | 200SX (USDM FWD)
Old 04-17-2007, 08:59 PM
nismo_pilot nismo_pilot is offline
Send a message via AIM to nismo_pilot
Re: QR25DE engine
countdown to 60,001 miles....lol BOOM!
2005 Aztec Red Spec-V
Nismo header, ES MMI, AEM CAI, UR Pulley, TB Coolant bypass, TWM SS, Kumho Ecsta's, 2x JL Audio W0 subs
9.02@ 84.4mph in the 1/8th....... Driver > Car
Old 04-17-2007, 09:20 PM
06chill's Avatar
06chill 06chill is offline
Re: QR25DE engine
you mean cuz of oil consumtion...because all you have to do is go to a dealership once when you get the car and they will either tell you its ok or fix it and most of the engines affected by the recal are covered for 100k miles. or if you check your engine oil like everybody who owenes a car should, especialy if you drive them hard. and i have yet to see one catch fire or blowup
Old 04-17-2007, 11:18 PM
Chiquae07's Avatar
Chiquae07 Chiquae07 is offline
Send a message via AIM to Chiquae07 Send a message via MSN to Chiquae07
Re: QR25DE engine
its not about oil consumption only. btw, the new qr25de that is in the 07 spec-v has 2 header pre-cats. im not kidding either. that kinda blows.
the reason for prozach to say time bomb is for the following:
1. precat failure in header, breaking up and entering the block
2. butterfly screwed from the intake manifold, through the whole block
3. large dispacement with large stroke = low rpms and more than plenty vibrations. the vibrations are 'eliminates' with the balance shaft in the oil pan, spinning in the oppisote direction of the crank. has known to cause oil problems in auto-x.
4. oil consumption
5. very sensitive knock sensor
6. coolant known for getting into the head gasket
2008 Mazda 6 ATX 2.3 Liters of Slowness
For those 9 seconds it takes me to reach 60mph, will be the most fun ill have in this car.
Old 04-18-2007, 09:42 AM
Re: QR25DE engine
you mean large displacement with LONG stroke, makes for very high piston speeds and they come with super hard rings so oil consumption is inevitable
Old 04-18-2007, 09:43 AM
Re: QR25DE engine
im going test driving today, im going to flog the piss out of one of those new specs and see what its got, also on the list are both the new evo and sti, along with the s2000 and a bmw 330ci opcorn:
Old 04-18-2007, 01:28 PM
Chiquae07's Avatar
Re: QR25DE engine
s2ks are really nice. but they are too expensive for me. the 330cis are nice too. i drove both. id take the s2k if i had another car for a daily though. and the 330ci is a great car too.
make a write up of your review.
Old 04-18-2007, 09:21 PM
06chill's Avatar
Re: QR25DE engine
and every single on of the problems you mentioned are simple fixes at a dealer and they are free to you. also its been years since ive seen precat problems. dont work an any sentras or sers with knock sensor problems...and like i said the engine is covered on most of them for 100k.
Old 04-18-2007, 10:04 PM
Re: QR25DE engine
thats if you have a dealer willing to work with you, ive heard shitty stories about 20 million times more than good stories about the dealership, and fixing high piston speeds isnt a quick and easy dealership job, it takes a new crank, crank position sensor, rings pistons rods wrist pins and a lot of time, none of which is covered under your mythical 100k warranty because the dealer thinks its should be set up to burn oil and that its "normal"
Old 04-18-2007, 11:15 PM
06chill's Avatar
Re: QR25DE engine
well it really isnt dealerships call its a recal from the factory and they dont change the pistons and stuff they just put a new longblock in it. the dealership has no right to tell you they wont fix it if it falls under the recal or the warranty extention
Old 04-19-2007, 07:35 AM
Chiquae07's Avatar
Re: QR25DE engine
they will blame it on you for modding the car, most likely because you diddnt get an aftermarket header, and locktite the butterfly screws.
also, this is about the engine in general, not just the '06's. there has been so many dealers that screw you over before giving you a brand new engine, like the recall states. if you have a dealer that actually works with you, then you are lucky, as they want you to pay for the new engine.
Old 04-19-2007, 09:24 AM
Re: QR25DE engine
yeah youve got it right on about how its "supposed" to work, but it never does, they dont want to admit they fucked up by putting a long stroke motor into a sport compact and coupled with really hard/cheap piston rings that equals oil consumption, the only way to fix it right is to basicly rework the whole engine and change it, since that costs a billion dollars they would rather just swap the block, but then they want you to pay for it, i wonder if i blow up mine before my warranty goes if they will give me an 07 spec motor instead of another crappy 05 one?
