Go Back   Automotive Forums Car Chat > Toyota > MR2/MR-S
Old 09-12-2004, 02:29 PM
TRD2000's Avatar
TRD2000 TRD2000 is offline
Re: beams?
sorry dude... that'd be a MAJOR excercise... the engine is a 3S-G engine, so it would bolt in to the 89-99 Mr2 but not the series 1... it can be done dont get me wrong but its a different engine size to the 4A-G in the older Mr2.
Who needs AWD? i feel inspired by the original 911 turbo, my car will have more rubber sqeezed in its ass than Annabelle Chong! and it will go down as one of the greatest rides in history!
Old 11-17-2004, 01:56 AM
chengkhang chengkhang is offline
Send a message via AIM to chengkhang Send a message via MSN to chengkhang Send a message via Yahoo to chengkhang
Re: Re: beams?
Originally Posted by TRD2000
you mean like a beams engine?
i think beams is the guy that made toyotas VVT system so they named it after him... i'm not sure...bit like Mzda's "miller" cycle
HOWEVER beams is definately the VVT part however it got it's name....
ahh dude doesnt BEAMS mean:
BEAMS series ( Breakthrough Engine with Advanced Mechanism System )
Old 11-17-2004, 07:16 AM
JekylandHyde's Avatar
JekylandHyde JekylandHyde is offline
AF - Advisor
Re: Re: beams?
Originally Posted by gelcol
so the beam can be installed in my mr2 1987 complete axel,tranny,harnes, cpu if ordered in japan or jdm.
Yes, but it is not direct bolt in.
Many people have put the 3SGTE into the MK1, so there is no reason the 3SGE would not fit. As noted above, it will not be a direct bolt in ... but it will fit.
Sponsorship: Amateur Motorsports <-- Get the book! - books are now available for shipment
Old 11-17-2004, 12:52 PM
TRD2000's Avatar
Re: beams?
thanks Cheng.... never knew that.
Old 11-17-2004, 01:45 PM
Im JDM Yo's Avatar
Im JDM Yo Im JDM Yo is offline
Re: beams?
ooo sounds mystical. I didnt know that until today.
91 Black MR2 Turbo
Project GT28RS is now officially under way!
http://www.Cardomain.com/id/EvilMR2
Live in columbus, OH? http://www.ColumbusStreetracing.net
>>>MR2 Online.com http://www.MR2Online.com
Old 11-18-2004, 01:03 AM
Re: Re: beams?
yeap,... sure
Old 11-18-2004, 10:05 AM
ac427cpe's Avatar
ac427cpe ac427cpe is offline
Miata is always the answe
Send a message via AIM to ac427cpe
Re: beams?
jekyl... i wouldn't say "many" people have done the 1.5 swap, but it isn't impossible. however, for the 3sgte or the BEAMS engine, the main things are that you must be GOOD at wiring, and competant at welding.
i'm not sure the beams engine would fit though, as it is wider than a 3sgte. and there is almost NO room on the side with a 3sgte in a mk1.
a BEAMS powered mk1 was an idea for my next project
wanders off to find a tape measure...
hello, i am Dan
No more project cars. I wonder how long that will last...
Old 11-18-2004, 12:44 PM
TRD2000's Avatar
Re: beams?
ac427... when you get some results from the tape you wanna let us know.
beams engine is taller... and cause of the actualors on the cam wheels a little longer... but from what i can tell in the MK2 the intake wheel is the close one and the intake had VVT in the late model na's so...it should fir ok.
did you have any probs fitting it Cheng?
Old 11-18-2004, 01:33 PM
ac427cpe's Avatar
Re: beams?
ok, if you take into account the amount i can move the engine on the mounts that i welded into the car, there is approx. 4 horizontal inches and 1 and a half verticle inches of movement. i had to clearance the front and rear (yay for hammers + metal working tools) to fit the engine where i wanted it: so the axles don't have foreward or backwards tilt. it also sits pretty low in the car, i might be able to lower it a half inch, but that would have been pushing it.
so, if a BEAMS engine is more than 2" wider from side to side, 2 inches taller, and any wider front to rear (unless you want to cut into the car)... you are gonna have issues fitting it in a mk1
hello, i am Dan
Old 01-03-2005, 10:11 AM
Re: Re: beams?
ohhh ummm yes and no
you mean the cam,....... its very very close to the wheel well, i am gonna have to cut,......
but fitting was good, with all the right pieces,....... but had to take it out im using the tranny that was on that on in my 91 daily driver,...... but i did tak pic before i took it out,... sooo sooon it'll be up,... and ill try to list all the things i interchanged and did,....
Old 01-04-2005, 12:46 PM
TRD2000's Avatar
Re: beams?
lookin forward to those pics then...
