Old 01-12-2005, 08:04 PM
Andydg Andydg is offline
Re: Re: Best Off-Road Truck
Originally Posted by G35XAndTrailBlazer
Find an old Army Hummer for like 10 grand lol
or get a Blazer. They are pretty good.
Jeep Grand Cherokee.
Chevy Trailblazer
infiniti G35x (XD get it? cause it has AWD LOL)
I'm such a jokster
You wouldn't happen to know of a place that sells old Army Hummers would you??? Also Trailblazers aren't exactly in the same class as the Jeep Grand Cherokee for off-roading.
Old 01-12-2005, 09:20 PM
AlienEvolution's Avatar
AlienEvolution AlienEvolution is offline
Send a message via ICQ to AlienEvolution Send a message via AIM to AlienEvolution Send a message via MSN to AlienEvolution Send a message via Yahoo to AlienEvolution
jeeps = breakdowns........
"I have a Tundra '01 with 245k miles. Yes 245,000 miles. and only had to replace a lightbulb. This truck is bulletproof."
-ryba1000
Wurd.
Old 01-13-2005, 08:10 AM
G35XAndTrailBlazer's Avatar
G35XAndTrailBlazer G35XAndTrailBlazer is offline
Banned
Send a message via AIM to G35XAndTrailBlazer
lol We took ours Off the road once. It went through 2 feet of water, we went up this hill coverd in rocks. i thought it handld pretty good lol
Old 01-13-2005, 08:11 AM
Banned
Oh yeah, I dont know any places that sells old Army Hummers.
Check Ebay or look for them around the net.
Old 01-16-2005, 05:50 PM
Depends on the Jeep really. My dad's friend has an '04 Grand Cherokee since fall of '03 and hasn't had any problems yet. This girl I know from school has a '99 Jeep Wrangler X with no problems. Also my friend's dad has a late '80's Cherokee and the only thing he's ever had a problem with is the clutch and that goes out ever couple years, but they hardly drive it at all anymore.
Old 01-24-2005, 10:08 PM
Banned
I see alot of breakdown jeeps. One did it in our culdisake once
Old 01-24-2005, 10:56 PM
That might be but what you should look at are Consumer Report type of things...just because you see a few broken down doesn't mean that Jeep reliability is in question. I've seen a lot of broken down Hondas and Toyotas, but that's most likely because there's so many.
Old 01-25-2005, 05:09 PM
Banned
Well, jeeps arent as bad as Fiats and jaguars lol
Old 01-25-2005, 06:08 PM
kenny-1907's Avatar
kenny-1907 kenny-1907 is offline
Send a message via MSN to kenny-1907
In my opinion you can't beat a K5. I had a Full size Jimmy with lockers front and rear with 33's and there was not much that it would not go through.
**2007 Avalanche LT. **
6" Pro Comp lift
305/55/20 BFG A/T KO'S
K&N FIPK GENII
Flo Pro V force muffler & 4" slash cut stainless tips
Color matched front and rear Bowties
3" polished stainless bull bar and Nerf bars
Old 01-26-2005, 10:11 PM
I agree completely, perfect size, wieght, power, etc. for just about anything.
Old 02-12-2005, 08:53 PM
J-Ri's Avatar
J-Ri J-Ri is offline
I too would have to say K5 Blazer. I have a 3/4 ton Silverado, and it does great completely stock. I've pulled some lifted toyotas and nissans out of deep mud, then go through myself only to see them try again and get stuck once more. The K5 Blazer is pretty much the same as my truck, just shorter which makes a BIG difference on trails. If you end up getting something other than a K5, buy anything but an import. They do ok... but they break a lot more than beefy American made trucks. After all, you don't get good gas mileage by having lots of steel on it.
Old 03-16-2005, 04:53 PM
FordJunky FordJunky is offline
Send a message via AIM to FordJunky
id say early model bronco if they werent so damned expensive, toyotas are nice, k5's an broncos are great for it. the truck i reall want is the new ranger with the fx4 stage 2, friends has one and thing is great off road.
Old 03-25-2005, 10:26 PM
J-Ri's Avatar
I would like to add a Jeep Wrangler to my recomendation. I have a buddy with one, all he has is a 2" "budget boost" and 31x10.5 tires. He's probably spent less than $800 for the lift, tires, and rims; and it will go just anywhere a K5 will go. It's lower up top, and narrower, so it will fit through tighter trails. Although, in a big truck you can push trees a couple inches out of the way :-D
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
Old 04-04-2005, 08:56 AM
corbinwaterski's Avatar
corbinwaterski corbinwaterski is offline
For trails/sand I would definitely go with Toyota Tacoma TRD with rear locker, however for mud slinging...you need power...Chevy Z71.
WAR UTAH!!
Old 04-05-2005, 11:33 AM
Yeah those Wranglers can really do well. They probably have the same power to weight ratio as a K5 too.
