Old 09-07-2004, 03:15 PM
StephenDeli's Avatar
StephenDeli StephenDeli is offline
Send a message via AIM to StephenDeli
Re: Lacquer dangers?
Im beggining to spray only acrylics as they are less dangerous...
Current Projects- Ferrari F189 ON HOLD
Ferrari 360 Spider
Future Projects-04' Corvette Z06, Enzo, F1-2000
Old 09-07-2004, 05:38 PM
RallyRaider's Avatar
Zomby Woof
If anybody is spraying lacquers without a respirator then stop right now! You need a respirator. Go to an Automotive paint shop and ask what kind you need, don't skimp, it is your health, look after it.
Old 09-07-2004, 06:34 PM
mike@af's Avatar
mike@af mike@af is offline
Captain Over Engineer
I've been painting using lacquers, urethanes, epoxys, etc for a few years now, and I strongly advise you get a nice dual cartridge respirator.
Duplicolor's and other products that you do not get through specialty stores are less dangerous, but still dangerous. Other paints from specialty stores, like HoK, PPG (especially the some of the primers and clears), and other high end paints are definately more dangerous.
To make it short, get a respirator.
-Mike
Old 09-07-2004, 06:59 PM
geofroley geofroley is offline
Send a message via AIM to geofroley
Re: Re: Lacquer dangers?
Thanks Mike and everyone. Any specific brands or just dual cartridge? Should I go to an automotive store like Pep Boys? Thanks for all the help guys.
Old 09-07-2004, 07:43 PM
minniebanister minniebanister is offline
Re: Re: Re: Lacquer dangers?
I use a dual cartridge respirator from AOSafety. You can find them via google. 3M make good respirators too I think. A respirator without cartridges should cost you $15 - $20. A pair of cartridges should run around $10 - $14. I brought mine in my local hardware store. Pep Boys ought to have the right stuff.
It's important that you buy the right cartridges. My cartridges say this on them...
For Organic Vapors, Mists of Paints, Lacquers & Enamels, Dusts, Mists, Fumes, Asbestos-Containing Dusts and Mists, Pesticides, Radionuclides and Radon Daughters (yes, they really do say that last item).
They are Combination Cartridges R51HE. ("HE" stands for "High Efficiency"). I brought them when I was removing some really old floor covering and I was scared of asbestos. You probably will not be spraying your models with asbestos so you probably only need ones which catch organic vapors and paint mists. However, if the ones which also catch particulates cost just a few dollars more, it's probably worth it.
Edit...
Hey Pat, I just noticed another thread in which you said you were gonna go to Sears. That's just the ticket! Craftsman model 18574 costs $39.99 including catridges. Replacement catridges cost $14.99. Will protect you against everything including nuclear explosions.
Old 09-07-2004, 08:23 PM
mike@af's Avatar
When you go to replace the cartridges, check out some specialty carbon cartridges. I've never used them in my mask, but I've used them in a fellow painters, they are amazing. I believe the were carbon cartridges...I'll double check.
-Mike
