#16
Re: 2.8 v6 multiport injection problems
I replied to your email
well you must have sent it to who know where, cause its not in my inbox !!
#18
Re: Re: 2.8 v6 multiport injection problems
Did you change your fuel filter? It could be clogged up..
Heres a quick way to test your fuel pump, (although new, it still could be faulty) and to make sure your getting fuel.. Under the hood on the driver side, there will be two stainless steel fuel lines.. Disconnect the feed line (careful, its under pressure) and stick the end into a container.. Have someone watch it while you put power to the fuel pump.. You should get 1/2 pint or more in 15 seconds.. Under your steering column, there is the ALDL diagnostics connector.. The terminal on the bottem row, farthest to the driver side is your fuel pump.. apply battery voltage to this terminal to turn the fuel pump on..
1991 Camaro Z28 |
