Go Back   Automotive Forums Car Chat > Ford > Ranger | Courier
Old 09-16-2004, 04:04 PM
worm6 worm6 is offline
right or wrong i used carb cleaner. came right off
Old 09-18-2004, 09:26 PM
juliuszx6 juliuszx6 is offline
Thank you Worm.Mine is a 93 too.I looked at it today, I see what you are talking about.I haven't cleaned it yet ,but I will first chance I get.Thanks again for your help.
Old 09-18-2004, 10:43 PM
now mines a 93 so yours could be different but you have the air box with you air filter. and then you have maf to the air intake tube to your motor. now all you need to do is take off the two screws on top removes the sensor be careful with it clean off put back on no need to crank down on the screws. before you start pull off ground cable on battery to reset computer. just leave off till done or 15 mins or so.
Old 09-19-2004, 06:55 PM
Re: 94 Ranger Starting Problems
ccc
Old 09-27-2004, 06:19 AM
1994RangerMan 1994RangerMan is offline
so i changed my IAC and it helped but still the same old problem if it sits for a while... like over night..
you think cleaning the MAF will fix the problem?? what do i clean it with
Old 10-06-2004, 06:27 AM
The garage cant even seem to find the problem.. do you guys have any ideas?? if the MAF was dirty or whatever, it would pop the computer at the garage wouldnt it??
Old 10-06-2004, 09:17 AM
316atO 316atO is offline
Change your o2 sensor. This i think, will clear up the problem.
Old 10-07-2004, 12:31 PM
splashiod's Avatar
splashiod splashiod is offline
here's some instructions on cleaning MAF http://www.rangerpowersports.com/for...t=cleaning+maf
hope it solves your problem. Good Luck!!
Old 10-08-2004, 06:19 AM
i was also told to change the temp sensor, you guys think that could solve the problem??
Old 10-08-2004, 12:03 PM
Connavar Connavar is offline
Send a message via AIM to Connavar Send a message via MSN to Connavar Send a message via Yahoo to Connavar
my 93 3.ol has the same prob so I'm gonna work on it tonight thought I would clean battery wires they look corroded then try and clean the MAF. We'll see if it is enough.
Old 10-11-2004, 05:43 PM
Did you ever find out anything on your starting problem?? Mine is going back to the shop tomorrow.. they had to call some tech line, they said to look for vaccum leaks along the fuel rail, check the O2 sensor, and i was also told to check the temp sensor..
Old 10-11-2004, 05:59 PM
Actually I checked mine out looked at anything that seemed wrong and I replaced the selonoid coil that didn't fix so I put a new battery terminal in and that seems to have fixed the starting problem. Now if I could fix the idle problem =(
Old 10-11-2004, 07:37 PM
so now your truck starts, but it doesnt idle right or what?? so yours has the same idle problem as mine??
Old 10-11-2004, 09:26 PM
yup it starts fine but i still got a weird idle sometimes
can't seem to figure it out though
Old 10-12-2004, 06:04 AM
i will post on what i find out from the garage tomorrow.. hopefully it will give us some help..
