Old 09-27-2004, 04:39 PM
Sporttruck85 Sporttruck85 is offline
Re: lowering spindels
A friend of mine has 295-50-15 tires on the rear with a 5" backspacing on a 10" wide wheel. He was able to drop hisin the rear 3". If your tires are so big that you cannot drop them that much then you are probably running into body interference when you hit a decent bump. If you can hit big bumps in the road and not rub then it should be able to be lowered. If you do get to lower it you will appreciate the improved handling
