Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 08-29-2004, 02:12 PM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
Re: '99 Starting Problems...
Be glad you don't own a 4Runner
Old 08-29-2004, 03:17 PM
yotatechie04's Avatar
yotatechie04 yotatechie04 is offline
Send a message via ICQ to yotatechie04 Send a message via AIM to yotatechie04 Send a message via MSN to yotatechie04 Send a message via Yahoo to yotatechie04
Actually, I am glad I don't. I've heard the starters are a pain in the a$$ to get out on them.
1994 Pontiac Grand Am GT - 3100 V6
1992 Chevrolet Lumina Euro - 3100 V6
1997 Ford Escort - 2.0 I4
"She only squeals when she's wet..."
Old 08-29-2004, 03:47 PM
Brian R.'s Avatar
Resident Chemist
They aren't that bad, but they are trouble. Might as well replace the starter with one made of titanium and aircraft engine bearings as pull the starter to replace the contacts.
Actually, it might be possible to remove the starter, but not pull it from the engine compartment. Just remove the solenoid in place and fix the contacts. Never tried it.
Old 09-02-2004, 11:43 AM
calvic calvic is offline
Re: Re: '99 Starting Problems...
Originally Posted by Brian R.
calvic - To be sure, no cure works all the time, but if you're smart, you try the cheapest and most likely ones first. It doesn't get much cheaper than solenoid contacts and this is a common problem.
Well if the starter solenoid is pulling then I figured the relay is doing the job. I figure heat is increasing the resistance in the circuit. Well I'm gonna try the extra relay with a extra 12volt cable to the solenoid. It seems to work on the GM starters
JJ
1988 Camry LE
4 cyl Auto
335,731
1994 Volvo 940 Turbo
1992 Dodge Cummins Turbo Diesel
2006 Mustang GT
