| Search | Car Forums | Gallery | Articles | Helper | Air Dried Dog Food | IgorSushko.com | Corporate |
| Latest | 0 Rplys |
Show Printable Version | Email this Page |
#16 | |
![]() Join Date: Nov 2003
Re: no more SMALL small blocks??????
seems like a step backwards to me. the LT1 conversion is only worth 8hp over a superram, and sacrifices nearly 30lbsft of torque, not to mention requires a helluvalot of modifications to make it work. its an interesting idea, but methinks ill pass on that one.
Chevrolet Camaro - I enjoy beating the hell out of people http://www.automotiveforums.com/vbulletin/showthread.php?t=68052 |
#17 | ||
Re: Re: no more SMALL small blocks??????
I dont mean to tell the mod what to do, you may know all of this. Just hate to see someone put a bunch of money into something that will turn into a pile of metal the first time they torque it up.
1969 Cougar 357w & TKO - 475hp |
#18 | ||
![]() Join Date: Apr 2004
1995 Camaro Z28, 383ci 485+hp 495ft-lbs SOLD!!!
1965 Ford F100 1967 Chevrolet Impala (Sold) 1972 Chevrolet Chevelle (Sold) 1972 BMW R60/5 (Sold) 1980 Harley Davidson FLH 1987 Harley Davidson XLH 1992 Astro EXT AWD 1992 Chevrolet Cavalier 2000 Monte Carlo SS Pace Car 1087/3222 (Sold) 2001 Pontiac Sunfire 2002 Trailblazer LTZ (Sold) South Carolina F and Y Bodies www.SCFYB.com |
#19 | |
351wStang, very good points, trust me, this engine has been slowly evolving over the past 6 or 7 years on paper, ive been tweaking ideas, and ive pretty much put everything into concideration, ive got my bases covered, but that dosnt mean i have to show all my cards i mean there is a little mystery left to street racing after all
my goal is to have the engine compartment look as stock as possible, obviously the superram intake wont help in that regard, but the car will basicly be a sleeper, only outside changes will be 17in chrome torque thrust II's, and 302 badging on a 1in cowl hood. only change inside the car will be a ratchet shifter, and a custom 8 speaker sound system. the drivetrain is where all the mods will be. but hopefully it will be pretty stealth. as far as reaching those engine speeds on the street, i dont plan to durring regular driving, just while im racing, and with the 700R4 getting up there isnt a problem. but when im done with it it will have 8 forward speeds and a lockup converter, so ill also have no problem cruising with good mileage basicly ill be able to cruise, at lower rpms than with the stock 2.73 rear end, even if i put 3.42 gears in it, or even 3.55 gears. with the 700's 3.06:1 first gear, and the way im building the engine, spinning it up will not be a problem. Deadcarny - yeah i understand the point of the LT1 intake with its shorter runners, resonance tuning and all that. (aka ram charging) but i still dont think its worth the extra work involved, and also, the sacrifice of torque in the bottom end is a big deal yes the torque curve is peakier on the superram, but even so the entire curve is above the LT1 curve even as the SR curve is dropping, and then they drop together. but yes cam choice does play the key roll here, and i am currently working on my own design. baised off the original 30/30 cam used back in the day, but im modernizing and "tweaking" it a little to better match the more modern engine.
#20 | |
![]() Join Date: Jun 2004
All I can is that I think that is going to be one hell of a engine and that car is gonna go like a bat outa hell
#21 | ||
#22 | |
You should put that 302 into a 1st gen while you're at it.
#23 | |
![]() Join Date: Oct 2003
i have no idea what is going on, but i love it!!
*Better power-to-weight ratio than a C6 corvette* |
#24 | |
i thought a 327 was a 350 block?
1968 Camaro 327 1999 Silverado 1500 Z71 LT {o,o} |)__) -"-"- O RLY? http://www.cardomain.com/id/korndogg002
#25 | |
until I think 1986 all SBC used basically the same block. Mainly it was just the Bore and Stroke that were different. (400 Small Blocks were different though, they had siamese Cylinders and a few other things)
#26 | |
yeah the blocks were the same, but i think what core402 is talking about is the casting numbers, from one number to another number was designated to become this kind of engine, and such, but when they made the 302's they just grabbed em off the shelf. but yes, as far as the 350 to 327 blocks physical similarity, they were identical. oh and the LT-1 in 1970, very bad ass, you know why???? it was a stroked DZ302
same heads, same cam, same block, just put a 3.48in stroke crank in where the 3.00in stroke crank had been. at least thats my understanding of it.
#27 | |
I need a 350 to move my truck and get decent mileage. I thought about taking the motor out of my caddy and putting it in, but its too small. And I know allll about winding up an S2000, and lemme tell ya, when you wind it up, it go reaaaaal fast.
#28 | |
Just being technical. The 327 and the 350 were the same after 67 when the 350 came out. Prior to 67, or some year, the 327 had the smaller mains. 350s and the later 327 had the medium journals, and in 1970 when the 400 came out it had the large main journals.
