Old 08-30-2004, 10:00 PM
wildstringer's Avatar
wildstringer wildstringer is offline
the only way i know to test it would be to install yours into another car that is running. of course it would have to use the same one or compatible . if the running car starts yours is good.
Old 08-31-2004, 12:34 PM
spider1604 spider1604 is offline
Re: 89 Mustang LX (HELP!?!)
I didn't notice if anybody covered it and I also don't know if an '89 has one or not but my son's '91 had a similar problem. Engine would turn over but never start one day (or week) and then it would start. The problem on his was his crankshaft sensor was bad.
Old 08-31-2004, 09:56 PM
351wStang's Avatar
351wStang 351wStang is offline
Good point. A car will not start with a bad crank sensor. The crank sensor reads "pulses" from the pulse ring. This is what tells the injectors when to spray (I beleive, its late and I dont remember exactly but I'm pretty sure thats what it does).
1969 Cougar
357w & TKO - 475hp
Old 09-04-2004, 04:44 PM
Amy has a Mustang Amy has a Mustang is offline
Send a message via AIM to Amy has a Mustang Send a message via MSN to Amy has a Mustang Send a message via Yahoo to Amy has a Mustang
Re: Re: 89 Mustang LX (HELP!?!)
If this was the prob, would the car be getting fire and where would this be located at? is it easy to change? do u have to relieve the preasure in the gas lines to change this?
many questions,
amy
Old 09-04-2004, 04:46 PM
we checked out the map sensor and it turns out that its bad, would this cause it not to get fire? how do u check fire on the coil?
more questions,
amy
Old 09-04-2004, 06:06 PM
SVTcobra306's Avatar
SVTcobra306 SVTcobra306 is offline
I'm guessing this is a 4 cylinder car if it has a crank sensor and a MAP sensor...but if it had a dist. cap and not a coil back it shouldn't have a crank trigger, it uses a PIP in the Distributor.
Have you run codes to see if it throws any? a bad module or a bad Primary Ignition Pickup will throw one, usually a MAP sensor will too. Usually, though, a bad MAP will simply cause the car to run really crappy.
When you turn the key on do you hear a hissing or a "Wheeeeeng" in the rear of the car (the fuel pump coming on)?
When was the last time the fuel filter was replaced?
I'm kinda batting at air here, not much info has been giving.
I am assuming the car cranks but does not start, has a full tank of gas, a new set of properly gapped spark plugs and new wires, cap, and rotor, and a new TFI module.
1994 SVT Cobra. 306, Ported GT-40X's, Crane 2031, NX Wet Kit (100 shot for now),TKO 500, TwEECer R/T, and all the bolt-ons.....
http://www.cardomain.com/id/mccobra94
1995 F-150 SC/4X4 351W/E4OD, K&N, Custom Exhaust w/Flowmaster.
Freedom Isn't Free.
Old 09-04-2004, 06:50 PM
i have replace the module, roter and cap, spark plugs, spark plugs wires, (yes they are on correctely according to the tiltion book), have replaced the altonator.
took the coil and had it tested and they said that it was good... fuel pump is working, (i hear it), its just not getting any fire.
All I know...
Amy
Old 09-04-2004, 06:52 PM
how much is a code tester and where do u plug it in at?
confused...
Amy
Old 09-04-2004, 07:29 PM
4" piece of wire, find the EEC test connector, wire the small single connector to the big connector. The one to wire it too: Hold it so there are 2 plugs on top and 3 or 4 on the bottom, plug your wire into the top right. Then get in and turn the key on, and read the flashes of the Check engine light. Your Chilton's manual should have what the codes mean.
BTW an '89 four cyl is EEC III not EEC IV...
Freedom Isn't Free.
