Old 08-18-2004, 09:19 AM
Chevyracincamaro's Avatar
Chevyracincamaro Chevyracincamaro is offline
Re: Blown head gasket?
i believe that the motor would be too far back. ive never tried it before, and based on what these guys said about the LT1's, i dont want to say that you cant. i dont see how you could get to the bolts in the rear of the intake manifold and heads and such because of the cowl area, but maybe it can be done. perhaps, one of these guys would be nice enough to go a little indepth into how they accomplished it, cause i myself would like to know...
*Better power-to-weight ratio than a C6 corvette*
Old 08-18-2004, 11:12 AM
Xbox2202 Xbox2202 is offline
Send a message via ICQ to Xbox2202
Ok, I called a few local shops today, and the lowest I've gotten so far is $640 just for the service, not counting parts. So if anyone has done this with a v6 motor and knows it can be done, let me know, because if I can't do it myself it will probably be parked for a while.
1994 Camaro V6 A4 - RIP 3/1/06
http://www.cardomain.com/memberpage/805164
1994 Camaro Z28 A4 - Bought 4/6/06
Old 08-18-2004, 12:26 PM
4onFloor's Avatar
4onFloor 4onFloor is offline
if they are only charging $640, i'm thinking that they do it without pulling the engine. If they had to pull the engine out, it'd be a lot more than $640. a GM dealership wanted almost $1000 just to change the intake gasket on my sister's grand am last year.
Old 08-18-2004, 12:36 PM
Jm93's Avatar
Jm93 Jm93 is offline
Send a message via ICQ to Jm93 Send a message via AIM to Jm93 Send a message via MSN to Jm93 Send a message via Yahoo to Jm93
i am replacing the headgaskets, along with almost everythign else, withou pulling the motor in my 84 T/A. just mark wich hose goes where and wich bolt is for what, and its easy to do yourself.
http://members.cardomain.com/jm9301
It runs once more. Parked for winter.
Old 08-18-2004, 01:03 PM
I called the local gm place and they wanted 1000+ to fix both, because I'm not sure which one it is yet. If someone that's already did it before could reassure me that it is possible, that would help me out.
Old 08-18-2004, 01:40 PM
4onFloor's Avatar
if you can, take some pictures of the engine bay. that'd help judgment a little bit
Old 08-18-2004, 03:41 PM
I don't have any pics of the engine bay yet, but if you have a hayne's manual it shows it in the book. Also, it's basically all stock, so if you can find any online you can see. I went outside and checked it , and there seems to be a lot of room to work around stuff.
Old 08-18-2004, 03:47 PM
96Civ's Avatar
96Civ 96Civ is offline
If you had a seriously blown head gasket, would your car run like shit but still have high compression?
Old 08-18-2004, 04:53 PM
4onFloor's Avatar
a blown headgasket doesn't mean it's completely shot, it's usually a bad spot between a cylinder and a water jacket, and is usually accompanied with overheating
Old 08-18-2004, 05:05 PM
you can rip apart a third gen without taking out the engine, this i know. i know that on the fourth gen v-6s the cowl extends into the engine bay and covers half the engine. there's about 1 to 1 1/2 inches of clearance between the sheet metal and the intake manifold. i personally dont know how you could do it but if these guys say they have done it than guess you can. i personally dont see how...
Old 08-18-2004, 06:12 PM
I went to camarov6.com and they told me that I can do it. I figure that they would if I can do it or not.
As for it overheating, I was overheating, like the previous message said.
