Old 02-14-2002, 07:52 PM
CRXkid CRXkid is offline
Send a message via Yahoo to CRXkid
Ok, if i were to go with the B16A, i have three questions. At nippon they have a package for the engine, tanny, and ecu. they also have one without the ECU. would the engine have better performance if I got like a type r ecu instead? is this even possible?
My second question is do I have to get the engine with the cable tranny form 88-91, or could i get the engine from 92-up? will it matter?
and my third question is about how much should it cost to install the engine? and what things should i know about when trying to find someone to install it?
Old 02-14-2002, 10:11 PM
spy54's Avatar
spy54 spy54 is offline
Send a message via AIM to spy54
um it unsure about your first question but you are also going to need axles, secondly yes you gotta get the one with the cable tanny pretty sure and it will cost any where from 1000-1500 depending on where you get it done your gonna want a place that does honda swaps often and see if they have done the swap before one of the worst things can be is an inexperienced shop doing a hack job on your install
AF Teen Crew
Purehonda.com - may she rest in peace
1996 Chevy C1500, Flowmaster Exhaust, Tinted Windows, 2 Kicker 10" L7 Subs, Eclipse 5v headunit, Alpine V12 Amp
DJM 4/6 drop kit being sold
Full Throttle 9.5 inch lift being installed
1989 CRX si "silver mist"---SOLD---.....Stripped and Wrecked in Compton
corbeau forza 2 seats, DC short shifter, Powerslot slotter rotors, AEM brake pads, Bfgoodridge Stainless steel brake lines, Greddy MX exhaust, AEM Cold Air Intake, Konig Rated-R rims, Kamikazi header
Make an Offer [email protected]
Old 05-12-2003, 03:50 PM
TKCRXBOY TKCRXBOY is offline
h22 will fit
you just have to stand on the fender and get a body hammer to push in the wall or cut a hole, thats so the altenator will fit.
Old 05-12-2003, 09:13 PM
TheRebirth TheRebirth is offline
Banned
h22a would be beastly if you could somehow get it to fit.
but consider your handling...if you really like it now...don't even think of getting an h22 - it'll give you some nice understeer
i'm sure theres away to work around that....but it'll probably be some kind of expensive suspension change..
also think about your weight distribution...it'll change a lot.
anyway...if you can dish out the cash to get the equipment to work around those handling problems...i say do it..
it'll be one vicious piece.
if not...i say get a b18c5 - about the same hp as an h22a4 - but less torque.
94 civic ex b16?b18?h22? royal661 JDM Motor & Parts info/chat 1 10-28-2004 10:30 AM
b16/b18 head gasket b16b bomber Engineering/ Technical 0 06-25-2003 05:01 PM
engine codes B18 H22 95 teg ls Integra 1 04-20-2003 10:08 PM
Honda B16/B18 rebuild books? jeffie7 Engineering/ Technical 1 04-07-2002 04:30 PM
What do you use to clean your B16, B18 valve cover? DOHCGSR Integra 3 09-01-2001 01:42 PM
