Go Back   Automotive Forums Car Chat > Nissan > Primera | G20 > General
General news, articles, other.
Old 02-06-2002, 03:07 PM
Mike.Com Mike.Com is offline
Originally posted by TRBOBRK
So how far can you go went the light comes on? After owning the car 5 months I only saw it come on once and then I put 13 gallons in it.
If you suck the tank dry, how bad is it to get it to start agian? ie. does the battery have enough juice to turn the engine enough to get the new fuel up there.
How many fuel pumps are there and what kind are they? Belt driven or Electrical?
On most cars, there are areound two gallons left when the fuel light comes on. On a G20, you should have around 50 miles left when the light comes on (@ 25 mpg).
It's not hard for a Fuel Injected car to restart after running out of fuel; It'll just take some extra cranking. It's not good for the fuel system if you do this. One time won't hurt though.
Fuel pumps in fuel injected cars are electronic. The fuel pump is usually located in the gas tank. I don't know of any fuel injected cars with belt driven fuel pumps.
-Mike C.
1995 Infiniti G20t
http://community.webshots.com/user/mike13bt
Old 02-06-2002, 03:27 PM
JustinP10's Avatar
JustinP10 JustinP10 is offline
Send a message via ICQ to JustinP10 Send a message via AIM to JustinP10 Send a message via Yahoo to JustinP10
Yeah, our fuel pump is located right behind the center of the rear seat, sorta between the cabin and the trunk. They are a pain in the ass to get in and out of the car mainly do to placement and working conditions (usually they go out at bad times). I helped replace one on a early model SE-R in the middle of winter in a walmart parking lot. It was like 10:00 at night when we started, probably 35-40 degrees outside, and all we had for lighting was a flashlight... at least it was a maglight... Oh yeah, I've heard with SE-R's that if you get below 2 gallons your car won't start. Like if you run down too low, you'll have to add at least two gallons of gas before it'll start. anyone experience this in a G?
Justin McClanahan
95 G20
15.4 @ 91.4mph (2.4 60ft )
143.7whp and 131.4 ft.lbs
Primera (10:1) Intake Cam, HS CAI, HS Header, UR Pullies, 19* Timing, ACT, Lightened Stock Flywheel, GC/AGX, Pacesetter Short Shifter, and more stuff...
Old 02-06-2002, 09:38 PM
TRBOBRK's Avatar
TRBOBRK TRBOBRK is offline
My Volvo had two. One that pumped a large quanity of gas at 5psi in the tank and one up in the engine compartment that boosted the psi up to about 150psi before it was injected into the engine.
Colin Gillespie - 1993.5 Nissan Primera - NWG20s
anyone know the 1uz-fe engine weight? Or a 430 series engine weight? Starbucks GS300/GS400/GS430/Aristo 0 02-12-2004 07:25 PM
WTD: Trade my 93.5 P10 Grill for your 94-96 P10 Grill??? WinterG20 Classifieds 1 05-13-2002 10:36 PM
slightly modified japanese p10 grill on my P10 WinterG20 Cosmetics 7 03-28-2002 10:40 PM
AWD Primera p10 VS. FWD P10 GoodJuan Suspension 5 10-17-2001 10:41 PM
P10 front seat question, and possibly problem ales Maintenance 2 03-25-2001 11:33 PM
