Go Back   Automotive Forums .com Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Silverado
Old 08-30-2006, 04:25 PM   #16
twowheel56
Re: Intermediate Shaft Steering Clunk
Okay folks sounds like I'm not the only one have this problem. I have a 2001 Tahoe that has given good service except for the intermediate shaft. The first one was replaced 2 months after I bought it and had been greased twice since and was replaced again(per the dealer paperwork) Feb 2005. Yep you guessed it, somethings gotta be done again. Has there been any new guidelines or anything Chevy is doing thats working now.
Sam
twowheel56 is offline   Reply With Quote
Old 11-23-2006, 11:45 AM   #17
K3CLT
I have a 2001 Tahoe.
I had the repair done at the dealer a few years ago and I think they replaced the shaft at that time. Now the noise has returned. I went to the dealer parts department and they said that they do not replace the shafts any longer and that they just lube them.
I bought the lube kit and will follow the TSB for removing the shaft and greasing it.
They say that there is no way to install a grease fitting on it.
K3CLT is offline   Reply With Quote
Old 11-26-2006, 08:58 PM   #18
intel_guy
There is another thread here which refers to an after mrket shaft with vibration dampener...this fixed the problem for that person. I just live with it.
intel_guy is offline   Reply With Quote
Old 12-03-2006, 09:16 PM   #19
tracmekanix
Originally Posted by Nave
SEEMS THEY HAVE ALREADY GIVEN YOU THE SHAFT..
huh good ?? I would think they would
Dose the problems with theses trucks Ever stop...
Had an 03 tahoe under warranty they said it was fixed. I picked it up after hours Saturday and took it back Monday morning. I had the service manager follow me out and I layed on the parking lot crawled on my back under it and grabed the pitman arm and shook it up and down making it rattle and said that is my problem.I picked it up Monday evening fixed. Since then I've bought 2 .05 duramax's a 3500 and a 2500 I just had the 2500 fixed. If they don't want to fix it try the number to G.M.in the back of you'r owners manual.
tracmekanix is offline   Reply With Quote
Old 12-03-2006, 09:27 PM   #20
tracmekanix
Old 01-16-2007, 10:50 AM   #21
rmeyerz
I've read the TSB for greasing the intermediate steering shaft, as outlined in this post, however, the TSB is for Silverado's up to 2003. Does the same 'kit' work for 2004 Silverado's, or is it a different P/N? Also, how much is this kit and do they provide the 'special tool' required? And finally, is this something I should let the dealer install, or is it relatively easy to do? I have a 2004 1500 Z71 Crew Cab with 50K miles and this clunk is driving me nuts!
rmeyerz is offline   Reply With Quote
Old 03-10-2007, 01:18 PM   #22
Eagle70ss
Hey guys,
Just went by the GM parts house this morning here in Big D and I was told the grease kit had been discontinued and was to be replaced with a redesigned shaft that is coming down the pipe...
Eagle70ss is offline   Reply With Quote
Old 04-29-2007, 07:29 AM   #23
sam karush
my 2002 silverado has the clunk. I plan on doing something about it, but in the meantime, am I creating alot of extra wear and tear or putting myself in danger by continuing to use the vehicle? I work on the road, so...
thanks,
sam
sam karush is offline   Reply With Quote
Old 08-05-2007, 10:02 PM   #24
ftxlcincy
I have a 2003 and had it to the dealer twice while under warranty. The first time they added grease, the second time they were supposed to have put the new shaft in but GM put a hold on that fix. I went back a few months ago and the service manager gave me a copy of the new bulletin that stated do not grease, or replace the shaft. Instead remove the connecting bolt, and stroke the shaft 8-10 times in the steering column and replace the bolt. I went home and it took a whole ten minutes, but the problem's fixed until next year. My guess is the grease settles down to the bottom of the column and the noise of the metal to metal contact is magnified through the column.
ftxlcincy is offline   Reply With Quote
Old 08-06-2007, 01:59 PM   #25
silverado122775
silverado122775's Avatar
So what you are saying is that your stroked your truck's shaft? You sick person.. I think you are a little too involved with your truck. LOL
2000 Silverado Z71, 5.3L, K&N GenII Air Intake, Y-pipe Exhaust (no muffler), Bosch Platnium +4 plugs, 242k miles and still running.
silverado122775 is offline   Reply With Quote
Old 08-06-2007, 03:51 PM   #26
fire24resque
fire24resque's Avatar
I replaced the shaft with the new one, it worked great for about a year and the new one is back to doing what the original one did, clunk and vibrate. They didn't really fix anything, they just gave you a new one and it just took a few twists and turns for the grease to wear down and you have the same problem on your hands again. I'm still trying to figure out how to fix it.
2001 Silverado 4x4 - 4.8 V8 - Hankook Dynapro ATm RF10s, 265/75/16
K&N FIPK - Flowmaster 50 Series 3.5" Duals
4-Headlight Conversion Kit - Billet Grille
90 Watt Nova Strobe Pack
2.5% Limo Tint -
Check Out Pictures and More Here
http://www.cardomain.com/ride/2131569/1
fire24resque is offline   Reply With Quote
Old 08-09-2007, 07:44 AM   #27
ftxlcincy
That was the exact wording on the GM bulletin. What the hell it solved the problem,for now.
Old 08-09-2007, 08:33 AM   #28
waitingforcolumbus
According to this advertisement there is a new steering shaft to fix this. It's about $60.
"GM has finally came up with a new design steering shaft for the clunking noise in your 1999-2007 GM truck. The part number is 19153614."
https://www.partszoneonline.com/index.php
waitingforcolumbus is offline   Reply With Quote
Old 08-09-2007, 09:15 AM   #29
silverado122775
Are you sure that is not just a replacement and not a fix?
Old 08-09-2007, 10:56 AM   #30
waitingforcolumbus
I don't really know except the ad says it's a new design to fix the clunk. I'm hoping a GM Certified mechanic or parts guy on this forum can tell me.
Can we get that to happen?
