Old 07-27-2004, 05:53 AM
Rufes1's Avatar
Rufes1 Rufes1 is offline
Send a message via ICQ to Rufes1
Re: Confused with camber kits.
ive already upgraded my suspension setup as it is, so its not really viable. And even if doing it that way it would mean the camber on that wheel wouldnt match the rest.
Msn; Click
Old 07-27-2004, 08:42 AM
TheSilentChamber's Avatar
TheSilentChamber TheSilentChamber is offline
Forunn Daberator
its just one wheel? have you thought about replacing the parts that you said you replaced with the right ones?
Old 07-28-2004, 03:01 AM
Rufes1's Avatar
I dont quite understand what u are trying to say?
The camber used to be a lot worse. The upper arm and knuckle hub were bent. The lower arm badly bent and obviously so was the radius rod, and sway bar.
All these parts have been replaced and the slight camber out is probably a sympton of the cross member being pulled slightly. However rather than replacing this It would be easy, seeming it would only be pulled by a tiny amount, to simply install a camber kit correcting the problem.
Msn; Click
Old 07-28-2004, 12:58 PM
Forunn Daberator
sorry, missunderstood. Thought you replaced them with the wrong parts and it made it possative.
Old 07-29-2004, 04:36 AM
Rufes1's Avatar
so im in quite a bind
Msn; Click
Old 07-29-2004, 11:02 AM
pauls81sc pauls81sc is offline
Cool Re: Re: Confused with camber kits.
Not really Rufes, here's a part from Ingalls that you can adjust to -1.5 deg.
http://www.ingallseng.com/parts/35590.htm
That will solve your problem, right?
1989 CRX Si (commuter)
1981 Porsche 911 SC (weekend TERROR!!!)
Old 07-30-2004, 02:54 AM
Rufes1's Avatar
yeh but bloody expensive hehehe
id prefer something that can go to -3 deg
i have seen a few on ebay that claim they can do +- 3 but i'll have to look into it more to see how valid it is
Msn; Click
