Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 07-26-2004, 11:29 PM
amigo-2k amigo-2k is offline
Isuzu Guy
Re: 2000 Rodeo CEL and Rough Idle
fyi: 99% of the time the EGR only needs to be cleaned (1-3 bucks for a can of carb cleaner), and not replaced.
-Ryan
-Ryan
Isuzu Moderator
Car Show Tips
Operations manager with a results-driven passion for process improvement
FAQ 98-04 Isuzu Rodeo, Rodeo Sport, Amigo, Trooper
SOLD - NOV2015 - 2000 Amigo, V6, HT winter, ST summer, 2wd
Old 07-27-2004, 01:02 PM
desmarkus desmarkus is offline
what are symtoms of an EGR being stuck Closed?
somebody said that the symtoms are more tolerable
2002 Chevrolet Venture, 3.4L 6Cyl. 4 door (4 speed automatic)
1997 Dodge Caravan, 3.0L 6Cyl. 4 door (3 speed automatic)
- Des Markus
Old 07-27-2004, 06:10 PM
rheteric rheteric is offline
Send a message via AIM to rheteric
The only symptoms I encountered with the EGR stuck in the closed position was the Check Engine Light. I got it read and that was the only thing that tipped me off to the EGR. The code translated was something like "EGR insufficient flow". With it closed it appears to do nothing to cripple the engine, it just might screw with the emissions and perhaps lower fuel mileage.
2000 Rodeo LS 4x4
3.2L w/cone filter
Full Manik S/S package
Old 07-28-2004, 08:12 AM
oh ... I'm having an rough idle issue. I've checked everything, I changed my EGR a while ago in attempt to cure the problem and was wondering if that could be the cause. guess not.
refer to my thread ....http://www.automotiveforums.com/vbul...d.php?t=260443
- Des Markus
Old 10-07-2004, 10:42 AM
tarcher1216 tarcher1216 is offline
Re: Re: 2000 Rodeo CEL and Rough Idle
I'm having the very same problem however they took it (EGR Valve)off last night and said they cleaned it . But this moring the light came back on. I hope a new part will fix the problem. The warrenty just expired about 300 miles ago Go figure!! I don't want to spend the money on new part if I don't have to. Maybe they didn't clean it correctly.
Any suggestions?
Thanks????
Old 10-07-2004, 06:05 PM
2eyefishclaw's Avatar
2eyefishclaw 2eyefishclaw is offline
Send a message via AIM to 2eyefishclaw Send a message via Yahoo to 2eyefishclaw
why why why? DO NOT LET THESE CLOWNS REPLACE YOUR EGR VALVES THEY NEED CLEANING WHICH IS A WHOLE LOT CHEAPER
Old 10-11-2004, 10:48 AM
Hello All... As promised... I thought I had the Check Engine light problem fixed but I didn't I clean the entire system and yes even the EGR valve and it still gave a code of 401. Well I started to think it might be a false reading until I asked the Auto Zone store to check the code again. Same thing.
I broke down and purchased the only EGR valve for miles around and installed it.
However a friend of mine suggested that I put a stainless steel screen over the opening on the EGR valve. I did this and installed with a new gasket.
I took a trip to Michigan over the weekend, about 430 miles round trip. NOT one problem. Except that the gas mileage sucked. about 17 MPG on the highway. I drove above speed limits but not by much. I stayed with the traffic flow. Anyway I do feel the problem is fixed.
Thanks to all that gave some input. It really helped.
Old 10-11-2004, 10:56 AM
rodeo02 rodeo02 is offline
Originally Posted by tarcher1216
a friend of mine suggested that I put a stainless steel screen over the opening on the EGR valve. I did this and installed with a new gasket...
Keep in mind you will have to keep that screen cleaned. It will act as a filter & plug with carbon.
G/luck
Joel
2016 Subaru Forester 2.5i base CVT
2016 Nissan Quest SV
Old 10-11-2004, 11:00 AM
Yes you are correct Since the EGR valve is very easy to get to I will check evertime I change the oil. Every 3,000 miles seems to be good. what do you think?
Old 10-14-2004, 10:17 AM
sbendigo sbendigo is offline
how much was it? is it something you can do yourself?
Old 10-14-2004, 10:44 AM
The screen was about 1.00 and the gasket came with the EGR valve. The valve itself was $120.00 . The service dept at the local Isuzu dealership which is so busy said that they could not get to my vehicle for about 1 week. I live in Indiana and there are only 3 Isuzu dealerships in the state. The chevrolet dealership refused to even talk about my problem. They said they were not taking anymore repair work on Isuzu What the hell is going on?
Anyway I fixed it myself and saved about $200 in labor charges.
The EGR valve is located on top of the engine towards the firewall behind and to the left of the carb. Only 2 bolts and a plug hold it in place. Very simple to replace. Glad I did my research before forking out that extra money for labor. Expensive part but very simple to fix if cleaning doesn't take care of it. In my case I tried to clean it twice and I found that the pintle on the valve itself was the problem so replacing the part was justified in my mind.
