Go Back   Automotive Forums Car Chat > Mazda > RX-7
Old 07-22-2004, 06:59 PM
D3rELiC's Avatar
D3rELiC D3rELiC is offline
Re: How long did it take you to drift?
you're welcome
Old 07-23-2004, 07:31 PM
EvoCrazy's Avatar
EvoCrazy EvoCrazy is offline
Send a message via AIM to EvoCrazy
The braking drift is also used a lot. Like he said, you just press on the brakes as you hit the corner, which makes your weight shift to the front, and the back will then slide. Is your car modded? When you first start use the stock turbos because they spool quicker than the bigger ones. Get an intercooler, and exhaust for power. But first get good suspension. If you want I can give you links to my friends site, and he can help you.
Old 07-23-2004, 09:57 PM
RevvRX-7's Avatar
RevvRX-7 RevvRX-7 is offline
Send a message via AIM to RevvRX-7 Send a message via MSN to RevvRX-7 Send a message via Yahoo to RevvRX-7
Well theres not much a jobless, greenless, 16 yr old can do to teh car for now..but work with what've I got..-sigh- Im starting to kinda look down on my 86 n/a..
Old 07-24-2004, 12:11 AM
flex339's Avatar
flex339 flex339 is offline
Send a message via AIM to flex339
I sometimes do braking drifts when I'm autocrossing, but it's not as fast as a grip run unfortunately.
Old 07-24-2004, 09:04 AM
EvoCrazy's Avatar
The braking drift will slow you down more, as where the clutch power over is much faster around the corner.
Old 07-24-2004, 01:45 PM
drftk1d's Avatar
drftk1d drftk1d is offline
boost in, apex seals out
Send a message via AIM to drftk1d
Re: Re: How long did it take you to drift?
The way you say this is like all rx-7s are turbo. Therye not.
Braking drift can be fast as well but the suspension must be tune so that the rear steps out upon braking more than stock.
I learned to drift in a go kart on a slippery track
RX-7 TII
Old 07-24-2004, 04:55 PM
Soyo's Avatar
Soyo Soyo is offline
Send a message via AIM to Soyo
yea braking drifts can be crazy fast... just have good suspension and go in way too fast slam the brakes hard, you'll go around quick, you just better know how to counter steer really good
1989 RX-7 TII --- Just got rebuilt and street ported
RB 3" dual exhaust, BNR stage 1 modified factory turbo, FCD, S-AFC II,
720cc secondaries, Aftermarket Turbo inlet duct w/K&N, Hawk HP+ pads
HKS Blow-Off Valve, Stainless brake and clutch lines
