Go Back   Automotive Forums .com Car Chat > Nissan > Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail
Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail Nissans greatest 4WDs and SUVs
Old 05-22-2001, 07:10 PM   #16
Synchro
Send a message via ICQ to Synchro Send a message via Yahoo to Synchro
Originally posted by Philosopher
I wish people would stop copying me.
YOU'RE WELCOME!
ok, smart guy. next time, i'll let you leave the c-clamps on. or whatever obvious problem you are running into.
Synchro is offline   Reply With Quote
Old 05-22-2001, 08:54 PM   #17
ChuckH
ChuckH's Avatar
Re: Hey Schlud
From the "posing on a cliff" pic, it doesn't appear that your springs are sagging at all (i.e. your rake is still stock-ish). True, or just appears that way?
BTW - I really dig the "spring flowers" shot and the Mt. Rainier pic.
Ha...Schlud's got the tallest springs I've seen yet on an Xterra! I don't know what he's complaining about. If I were in Schlud's position, I would just add helper springs for carrying extra loads. Then again, if he wants to replace them maybe I can get a good deal on his and I'll add helper springs to them!
BTW, I think I've actually gained some clearance in the back since I unloaded all my Moab gear. I'll have to measure again when I'm on level ground, but it actually appears that I'm at about the same as where I was before putting the bumper on. Ok, must go measure!
ChuckH
ChuckH is offline   Reply With Quote
Old 05-22-2001, 09:41 PM   #18
Mosi
Re: Re: Hey Schlud
Taller than Andy's?? That guy has like 5 feet between the axle and bumpstops!! My springs need serious help! With only 200lbs loaded, I am practically riding on the bumpstops!
Former 2000 Xterra 4x4 SE owner
Mosi is offline   Reply With Quote
Old 05-22-2001, 10:00 PM   #19
ChuckH
ChuckH's Avatar
Re: Re: Re: Hey Schlud
Yes, Schlud's got atleast an inch over Andy (That sounds soooo wrong!). Without the KMA on, my truck was about the same height as Andy's or maybe only a very small amount less in the back and Schlud's was 1-1/2 inches over me. For comparison, Schlud had 5-1/4 inches between the axle and the bumpstop and I had 3-3/4 inches. I still haven't looked to see what I have now. You had what...1/2 inch when we first got to Moab?
Schlud's truck has some serious rake to it. Remember how people were jacking up Camaros and such back in the 70's? That's how Schlud's truck looks...or atleast it did last time I saw it.
OK, I have between 3-1/4 and 3-1/2 inches between the axle and the bumpstops now. Can't get too accurate because my driveway is not level.
ChuckH
Old 05-23-2001, 12:37 AM   #20
Mosi
Re: Re: Re: Re: Hey Schlud
I've got a big whopping 2.5 inches between the bumpstop and axle with no extra gear inside! I am really close to taking it to the dealership so I can get the "Oh I'm sorry Mr. Mosi, you take your X off the pavement so NO WARRANTY FOR YOU! What's that? You and all of the others out there with Xterra Web sites have helped sell hundreds of Xterras? WE DON'T CARE! "
Okay, a bit harsh.... I am just preparing for the worst :frog:
Old 05-23-2001, 02:46 AM   #21
ChuckH
ChuckH's Avatar
Wow...you actually bounced up quite a bit after unloading though because you had maybe an inch max when we got to Moab! Remember, I have the shackles and still only have an inch over your truck. Of course I also have 120 lbs of bumper, a toolbox, and a subwoofer back there right now. I think a stock Xterra has about 3 inches or just over under the bump stops, so you're not really that far off and you have those skid plates installed. More than anything, I think you just carry a lot of crap or your springs just aren't very "springy" and aren't supporting when they need to. I'll try and keep my tape measure in my truck and check in a flat spot, but I don't anticipate too much difference. I think it's quite clear Nissan didn't put stiff enough springs on the Xterra and that's probably the main reason the load capacity is so wimpy (3 of me in one would overload it!). They were trying to keep the ride softer for the soccer moms I guess!
I will probably end up getting helper springs, as the National springs seem to be pretty soft too. Yes, they are taller when unloaded, but Ian Firth's really compressed when he was loaded up, unless that's the way the truck is suppose to sit with the 3 inch lift. I do know that his truck was lower in the back than Schlud's. I would rather give up some ride comfort and have the extra support.
Atleast you won't have to worry about it at Mt. Hood!
I'd go to the dealer, but I'd have to remove the shackles and the bumper, then would have a hard time convincing them the springs are weak. Besides, new ones would just sag soon enough.
I wonder if Schlud's going to hurt us for turning the Manastash thread into a spring thread?
ChuckH
Old 05-23-2001, 11:43 AM   #22
Philosopher
Philosopher's Avatar
FYI - I have 5 3/4" between bump stop and rear axle.
Philosopher is offline   Reply With Quote
Old 05-23-2001, 11:46 AM   #23
Mosi
Is that with or without gear?
Old 05-23-2001, 12:49 PM   #24
Philosopher
That is loaded down ... with an empty truck, probably more like 6.5 - 7" after installing the AAL.
Old 05-23-2001, 02:52 PM   #25
Mosi
I just went to the dealer and told them my springs are toast. He said "go check out a new X on the lot and see if there is a difference". I checked it out and said "yeah, there is twice as much space on the new ones". He said "okay, we will order some and get you in next week". DAMN!! He did it without even having a tech look at my truck! I guess it helps that he offroads too because he didn't give me any shit. SWEET!
Old 05-23-2001, 02:56 PM   #26
Philosopher
Very cool, congrats. When I went in to get mione replaced, all I had to say was "extended warranty" and they were installed a few days later.
Old 05-25-2001, 01:14 AM   #27
Schludwiller
XTerra Guy
Schludwiller's Avatar
Ben playing on Funny Rocks, WA
Grabbed a shot from video of Ben taking his wife down Funny Rocks.
Schludwiller is offline   Reply With Quote
Old 05-25-2001, 01:24 PM   #28
Antitree_hugger
Antitree_hugger's Avatar
Send a message via AIM to Antitree_hugger Send a message via Yahoo to Antitree_hugger
That was fun. How did the shot of us all on the stair turn out?
ben
Antitree_hugger is offline   Reply With Quote
Old 05-25-2001, 01:56 PM   #29
Schludwiller
XTerra Guy
Pretty good. I'll have more over the weekend. Plus some video!
Old 05-25-2001, 02:34 PM   #30
Antitree_hugger
SWEET!!
So you are not going to Mt. Hood?
