Go Back   Automotive Forums Car Chat > Nissan > Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail
Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail Nissans greatest 4WDs and SUVs
Old 07-04-2001, 07:08 PM
xterrabull xterrabull is offline
Finally got off my duff to take measurements...
I have 31x10.5 Yokohame Geolander AT's; 1/2 tread on rear, 3/4 tread on front. R is passenger side measurement & L is driver side measurement. Measurements are w/truck on suburban driveway of "average" slope. Disclaimer: I don't claim that these measurements make sense 100% .
I left Philosopher's measurements for comparison & added the Nissan factory measurement for the front ride height (located at bottom of the "front" section).
Overall, I'd say my car has *slightly* more rake than stock when sitting on level ground....
FRONT:
  • Ground to uppermost part of lower A-arm = 12"
  • R: 12", L: 12 1/8"
  • Ground to top of wheel well fender lip = 35"
  • R: 34.5", L: 34 3/4"
  • Ground to frame just behind first body mount = 15.5"
  • R: 15", L: 15"
  • (Ground to bottom of front steering stop bracket) minus (Ground to center of lower A-arm pivot bolt) = ?
  • R: 2 5/8", L: 2 5/8"
REAR:
  • Ground to frame just in front of spring hanger = 16.5"
  • R: 16", L: 16 1/8"
  • Ground to top of wheel well fender lip = 37"
  • R: 36 3/4", L: 36 5/8"
  • Ground to bottom of rear shackle = 18.5"
  • R: 19 1/4", L: 19 3/16"
  • Ground to bottom of rear diff = 10"
  • R: 9", L: 9"
  • Bottom of rear bumpstop to top of axle = 5.75"
  • R: 5", L: 4 7/8"
Old 07-05-2001, 12:17 PM
Philosopher's Avatar
Philosopher Philosopher is offline
Do you have the AAL and the shackles, or just the AAL's?
Old 07-05-2001, 01:49 PM
Sorry I didn't specify...
I only have the AAL & my OE springpack is still in good shape (which is another way of saying I don't get off road as much as I would like--GRRR ).
Old 07-05-2001, 02:16 PM
Schludwiller's Avatar
Schludwiller Schludwiller is offline
XTerra Guy
Re: Sorry I didn't specify...
Not true. The springpacks are just inconsistent. My pack is still good and I go offroading a lot more than people I know who have wasted leafs.
Well...maybe you don't go offroad enough. I'll let you speak for yourself on that one.
Old 07-21-2001, 09:19 PM
Aquamander Aquamander is offline
Send a message via AIM to Aquamander Send a message via Yahoo to Aquamander
Question Problem?
I've noticed that at full droop in the rear, my brakelines/vent lines were almost the point of no slack. It's a little scary. I know I can put longer lines and modify the bracket on the axle but I have too much lift in the back. (is there anything such as too much lift? hehehe) I don't think pulling the shackles will really decrease the lift in the rear as they are more for articulation than lift right?
I also had to make new 10mm spring pins! I stripped out one when I was trying to tighten the springs before I reinstalled the U-bolts. When I managed to get the stripped bolt off, I broke out the calipers and started measuring things. I found (at least on my X) that the OEM springpack had a thickness around 1.650" The new spring set-up, (+add-a-leaf / - the OEM load spring) came to a thickness of 1.375" The pin thingee is threaded to accept only about 1.400".
So I made a mad dash for the shop (my greasy ass in my wifes new Altima) and took some 10mm socket head bolts and turned them down to fit the hole in the axle bracket. I got home, started putting the new hardware on and discovered that the shock mount thingee didn't have a big enough hole to accept the new nuts that I was using for my bolts. So at 11:00pm I had to run to Lowe's and buy a 3/4 drill to modify the plate. I pulled the plates off the shocks and drilled them. I also noticed that by pulling the plates it made it easier to reinstall the plates once everything was ready to go back together. I had to use brute force to align the pins once I was ready to bolt everything back together. I had my wife at the helm of the floorjack, lowering and jacking as I realigned everything. (how's that for a woman, huh?) she did the standard bitch about starting a mod project in the middle of the week, but I think she was getting tired and cranky.
All in all had I been a little more prepared, I would have been ready to do the install a little quicker. I too am lifted in the front about as far as I can go without going with new uppers and ball joints. I like it, and the ride, I think is much smoother. Thanks to Todd and EOE for good buy on the AAL's!
I think this episode could fall into Syncro's dammit, dammit, son of a bitch class of install glitches!
Going to try them out tommorrow.....
Old 07-22-2001, 08:46 AM
Synchro Synchro is offline
Send a message via ICQ to Synchro Send a message via Yahoo to Synchro
just so you know, what you could have done was use the dies from a tap and die set and fixed the threads and extended them.
also, most of us reused the stock pin with no problems. hmmmm.. so you had to modify the shock mount plate? did i understand that correctly?
glad i can be quoted.
Old 07-22-2001, 10:12 AM
Yeah, but it was to late to save one...
True, I could have run a die on the stock pins. The first one was dead. I f'ed it up in order to get it off. The stock pins will work, it's just that it's not threaded far enough. (at least mine weren't) I used an 10m course thread to replace the OEM pins. As you may know, I'm a machinist by trade. Making the new pins wasn't any trouble at all. It was just a hassle to drive to the shop and make a pair. Like you said, the stock pins will work, (I don't see how folks are getting them tight without running the nut up onto unthreaded material.) I still think caution should be used to prevent stripping the bolt and/or nut. I just wanted to give the heads up. Most folks don't have access to a machine shop, so your advise on using a die would be the best way to prevent this problem. However, I think my 10m course thread is better suited for this kind of application courser the thread, deeper the pitch. less chance of stripping them in the future.
Yeah, since I used a different thread in a pinch, I had to use the nuts I had available to me. They needed a larger diameter hole through the shock mount plate. Not much mind you, I had to open it up by about 1/16 per side for them to fit.
I pulled the SLR shackles late last night. I was too worried about snatching the lines from the axle. I need to look into this further, see if I can find some longer lines and decide if I really need that kind of droop with the AAL's on. I decided to err in the favor of swapping out the shackles instead of tearing something up when I go wheelin' later this afternoon. I swapped them out in about an hour, so it's not much of a PITA.
I don't want to seem like chicken little here, I thought it was important to let others know that a potential problem may exsist.
Besides that, the AAL's kick ass. The ride on the road is greatly improved. I don't know about the rest of you but My X seems a little less bouncy...contrary to what skeptics have said about AAL's in other threads in other forums. The T-bars in conjunction with the AAL's are a vast improvement. Now it's time to see how they perform off road.
Thanks Syncro!
(p.s. When do you think you guys in the MAXC will be coming back down for a Tellico trip? I was sorry I missed the trip, it would be fun to meet and go wheelin with you. Perhaps this year's ECXC?)
Old 07-22-2001, 12:36 PM
gothamist's Avatar
gothamist gothamist is offline
I'm confused
How did the tension on your brakelines increase at full droop when you added the add-a-leafs? Wouldn't the fact you didn't change shocks or bumpstops mean that the brakelines wouldn't be any more tight regardless of whether or not you have the shackles installed?
At full droop mine are tight, but not guitar-string pluckable.
gothamist
Old 07-22-2001, 04:44 PM
You're right, the shocks would be the limiting factor!DOH! I'm a dufuss!
Of course AQUA X performed wonderful today. We went and crawled on some nasty big cobblestone hills. I only had to rethink one line. I stuffed the front right tire on a wheel hang and couldn't seem to get up on top of it. I had to back down the hill and start out on a different angle than before...now it's just like I want it! I think I may have pulled on the vent hose during the install and got freaked.
Old 07-22-2001, 07:02 PM
gothamist's Avatar
Right on. I didn't mean to be curt, it's just I went through the same thing--I ramped my X at Skid-Row just after the shackle install to make sure the brakelines were okay, at which point Eric (Skid-Row man) asked me why I was checking them...the shocks hadn't changed...I looked at him, thought it through a minute or two, and went..."oh yeah...I feel dumb."
Having said that, I would still like to lengthen the lines out a bit at some point, just for peace of mind...who knows, I could snag a tree limb or something and having a bit of slack would be nice. I think at this point though we're all getting pretty close to the limits of travel on the stock driveshaft...anyone know for sure?
gothamist
Old 07-22-2001, 10:28 PM
the tension of the srping pack is what we used to get the nuts off that bolt and to get them back on. whenever we needed tension we lowered the truck a bit and that put the tension we needed on there to tighten the nut.
as for tellico. who knows. there is no way i would run an event at telico. the trails are too narrow, to many people and the possibilites for damage too high for most people. when i go back there, i was thinking of getting a few people and renting a cabin and making a week of it. wheeling, hiking, fishing, drinking and good times. there is plenty to do around there. i just need to find a crowd of people interested in doing that. :-)
Old 07-22-2001, 10:54 PM
Wink It's all good...
Aw heck Goth, you weren't being curt, this is the positive constructive discussion that can be useful for those who follow the ol'mod trail so to speak.
I too have wondered about the angle of the driveshaft and the depth of the slip yoke. (does that make sense) This is another good question to ponder. I haven't really looked close at the assembly but I wonder how it's built and what kind of travel it has.
Brent, you care to comment on this?
Hell yeah Syncro, I'm in if you get something going. Our plans are wide open after the holidays. By that time people's pocket books will be recovered from GOX.
We should toss around the idea in the coming months. Perhaps we can generate some interest, get MAXC, SEXC, and FLXX clubs together. This will give me time to get my bullbar and sliders put on. I would be doing it this month but I have to have a tooth crowned, $580.00!
POOOF! there goes my bullbar fund.
Just how much are those old step rails worth anyways? hehehehe
Of course, we could all get together next Memorial Day and crash the Monteagle jeep rally! I know where everyone camps! :bandit:
Old 07-23-2001, 08:25 AM
OffroadX OffroadX is offline
Send a message via AIM to OffroadX
There's nothing in the ESM about the angle or the yoke depth, no surprise there.
Tellico is my old stomping grounds, used to go out that way all the time when I was young. Be sure and hike up to the top of Bald River falls, and go for a swim a way up above it. There are a couple of places where the river shoots through a narrow gap and you can float down the sluice and into a pool below. And no, you're nowhere near the lip of the falls itself.
If you want a fairly civilized place to camp, Indian Boundary isn't far away on the TN side. There's a nice little lake with a large sandy beach.
There is a nice little primitive campground a few miles up North River road, right on North River, and a couple of good swimming holes at the bends there.
A few more miles up there is a schweet old hunting cabin up the road past a very old log bridge that crosses the river. People still drove across that bridge but I sure as heck would be scared to. It's beefy, but it's past its prime. It's a nice hike up to the cabin.
Stratton Meadows is a nice place to chill out at the top of the mountain.
Brent
Old 07-23-2001, 11:17 AM
FSRBIKER's Avatar
FSRBIKER FSRBIKER is offline
Talking with SLR a few months ago about a possible driveshaft spacer when I go solid up front and spring over in the rear they did not think I would need one but could make one from old plans they have(I am not sure though if the driveshafts have changed over the years though). They are running their lift with the new spring pack and said they could go a few inches more before the driveshaft would slip out, I sure don't want to be the first to experience this so more research needs to be done to be sure.
Todd AKA FSRBIKER
EOE
www.Extreme4x4Parts.com
