#16
Re: Re: what's the major malfunction?!?!
did you use die-electric grease when you put all your wires back on??
1991 Camaro Z28 |
#18
i did it last night and didn't use anygrease. but that can stop the wires from sparking if they are already doing it? anyway, i haven't been able to put any of the good advice to use yet.
yeah it should stop the wires from sparking.. Providing the wires arent cut or melted anywhere.. where are the sparks coming from
and what type of wires are you using
1991 Camaro Z28 |
#20
the wires that i just took off were bosch, the ones I just put back on are old, not sure what they are, I only know they arent' melted
is it sparking from anywhere particular?
1991 Camaro Z28 |
#22
I can't see the physical spark, it's like flashes of light inside the #1, 6, & 8 wires.
hey what bout me??
![]() lol |
#24
hmm.... this is a tough one. id give ya some advice, but really, this is a job i would charge time and materials for, and just start testing circuits and components one at a time, ruling everything out rather than trying to decide what the problem was to begin with.
Chevrolet Camaro - I enjoy beating the hell out of people http://www.automotiveforums.com/vbulletin/showthread.php?t=68052 |
#25
that's what I thought.
surry darlin
ill do some brainstorming though, and see if i cant be more helpful.
#27
well, we are getting together to see if we can cough up the cash for a pro to do the job.....wish me luck....
check your battery grounds, the negative cable should split into three cables, one to the frame, one to the body, and one to the engine. seeing as the ignition system grounds through the plugs into the engine block, and there is about 45,000 volts grounding thought them, so if that ground isnt properly tightend it has to try and find another place to go, hence the sparking and flashing, its a shot in the dark, but its an idea
#29
ok, thank you for being so helpul.
well, somewhat helpful anyway
