#16
Re: 2004 Power Antenna Mast Replacement
Brian,
Thanks again and have a great 4th. Mike |
#17
Hey - You're welcome. Great 4th to you too.
#18
hello fellas...I just happened to have fixed my antenna today. I got the antenna out but the plastic wire thing wasn't attached soooo i removed the fender flare about 6 10mm bolts and there are about 6 clips two on the bottom by the running boardpiece (which you don't have to take off) then I think 4 more the unit is right there, one bolt removes that. oh and make sure ya take off the nut on top by the antenna. pull the unit down..there is 6 screws you have to remove, don't lose the nuts, only a couple have them. the one in the center and the one with the wire attached.slowly open it up and take out the white plastic wire thing with teeth.put back together put it back under the fender, feed wire in and turn off radio goes right in..too easy. hope this helps
#19
Thank you for the details. Someone will need them.
#20
Thanks hazie.
Mike |
#21
your welcome!
#22
brian, is there more info on this post, like what do u do when mast is out and u have new one ready for re-install. can u explain in detail how to re-install new mast
i've tried a few times and motor continues to run for about 5 seconds after antenna is in "up" position. |
#23
