| Forced Induction Discuss topics relating to turbochargers, superchargers, and nitrous oxide systems. |
#16
Re: TURBO EXPERITISE: TWO questions: 1. Difference... 2. Disconnected..
The housings, elbow, wastegate all are fine. It just needs new bearings/seals/wheels.
#17
I have a question about oil lines how does that work with turbo??
Simon R 2001 Silverado W/T 4.3 124,000 |
#18
Turbochargers oil supply is pressure fed and gravity drained.
Beer tastes better upside down. Last edited by Sluttypatton on 13-54-2098 at 25:75 PM. |
#19
now the oil is needed for the turbines right the reason why engines need oil same purpose???
#20
Yep, lubrication and cooling, although the cooling property is lesser in a water cooled turbocharger.
#21
when you say water do you mean antifreeze??
#22
Yes, water cooled is just a term used for it.
#23
how long do the bearings last??? would they wear out over time???
#24
Watercooling is mainly used to cool the turbocharger after the engine is shut down when the oil stops to circulate.
The bearings in a turbocharger are usually hydrodynamic, that means that they are floating on a oil film so the wear on the bearings is low. However, if you don't service it properly, or regulary shuts down the car with a red hot turbo they and the piston ring seal in the turbocharger can take damage. |
#25
uh oh so how would you service it take it to pep boys or something??
#26
Re: Re: TURBO EXPERITISE: TWO questions: 1. Difference... 2. Disconnected..
Re: Re: Re: TURBO EXPERITISE: TWO questions: 1. Difference... 2. Disconnected..
so in other words the turbo needs to be above the water pump???
#30
