Old 06-28-2004, 10:30 AM
metalhedskater's Avatar
metalhedskater metalhedskater is offline
Send a message via AIM to metalhedskater
Re: problem with UICP and 1gbov
well, i went to http://65.54.172.250/cgi-bin/linkrd?...all%2f1000Q%2f and it says i have to ground the diagnostic plug under the drivers dash which i did, but i have problems grounding a pin to the firewell used for the engine timing.....here it is from the site..You ground a pin in the diagnostic plug and you ground
a pin on the engine firewall that is normally used to set engine timing.
"Then you adjust the setscrew until the idle is stable at 750 RPM." (http://www.dsm.org/archives/1998/07/...20.txt/31.html) i did the procedure, but i forgot to ground the second part because i dont know where the hell it is....i read somewhere that 2g eclipses dont have the enging timing....so please help....but yea that was my problem so in case any of you have the same problem down the road....hope it can help! thanks guys!
