Go Back   Automotive Forums Car Chat > Mazda > RX-7
Old 06-24-2004, 04:35 PM
D3rELiC's Avatar
D3rELiC D3rELiC is offline
Re: Re: sequential or non sequential which is better?
Originally Posted by Soyo
yea haltech with manual tranny should be about the cost of single turbo upgrade I'd think... something to look into maybe
and i heard automatic trannys are weak when you reach 350-400hp, you'd have to change it anyway, do it before you blow it
Old 06-24-2004, 04:44 PM
aeaton21 aeaton21 is offline
KYRX-7, I don't know if you've answered this or not but what are your 3k worth of upgrades? Boost is not always a vac. leak. What are the symptoms and how's the idle? Do you have an A/F gauge? or aftermarket boost gauge? Let me know whats going on with the car and I can probably help you out. Are the factory cats on the car? What boost controller are you running...... So many things need to be answered before you can be pointed in the right direction. If you need a 5 speed tranny I might be able to help you out. I probably have everything you would need or know where it is. I had a car that we converted to an automotic after it was wrecked...... LONG STORY
Old 06-25-2004, 10:05 AM
kyrx7 kyrx7 is offline
thanks for trying to help. i am guessing on the upgrades.it has factory cat but it has a upgrade greddy cat back. dont know why the owner before me did that. it has a huge pf intercooler. greddy turbo timer, i bought a apex blow off valve but havent used it cause of the turbo problem.now answer me this. alot of people tell me that the air box has been upgraded. its not the square box that says mazda like the factory box it is a dimond shaped box that runs into the intercooler. is that a upgrade and if it is is it better than the filters that most people have on the cars. also i have a aftermarket boost gauge.i have no boost control.
o.k. this is what the car is doing.when i take off no matter what i do it wont make but 5 pounds of boost if i let off the gas a little you can watch the boost gauge go down a little then you can hear a whistle and the car will pick up speed letting off the gas because the turbo kicks in soon as it whisles you can push it to the floor and it will make 10 to 15 pounds???? now just 2 days ago i was driving and it was doing the same thing but something has happened because now when it makes boost it makes a loud shkoooooooooooooooooooooo sound. is that a leak??? i can make boost whenever i want except for take off buy letting off the throttle a little until it whisles just a faint whisle. what could this be?? is the twins bad or something else?
Old 06-25-2004, 12:50 PM
Hmmmm. Hard to say. I would look at 2 culprits, your cat and a leak. Pressure test the system and that will give you a good idea of a leak. Sounds more like a intake hose leak maybe a vaccuum. anyway, forcing the car to make boost may not be what you want it to do. Take of your cat and drive it down the block and see if that stops your problem. Your cat is probably fried. Hope that helps
Old 06-25-2004, 01:45 PM
D3rELiC's Avatar
dont drive it too long without cat, you'll run too lean and blow the engine.
Old 06-25-2004, 02:59 PM
I guess I should have stated only for a block. Don't run without one
Old 06-25-2004, 04:16 PM
Soyo's Avatar
Soyo Soyo is offline
Send a message via AIM to Soyo
glad you added that, I was afraid he was gonna kill his car
1989 RX-7 TII --- Just got rebuilt and street ported
RB 3" dual exhaust, BNR stage 1 modified factory turbo, FCD, S-AFC II,
720cc secondaries, Aftermarket Turbo inlet duct w/K&N, Hawk HP+ pads
HKS Blow-Off Valve, Stainless brake and clutch lines
Old 06-30-2004, 11:46 AM
checked the cat at my friends muffler shop and it was fine. he has the car today and gonna put it on the dyno so he can make boost and check the leak will keep you guys informed on the progress
