Old 06-22-2004, 03:17 PM
ashah000's Avatar
ashah000 ashah000 is offline
Send a message via AIM to ashah000
Re: middle tail light
It is VERY EASY! They hardest part is making the cig lighter hole bigger to put it in there.
For the button there are two wires 12v power and one that goes to the relay.
Then from the relay you tap two wires.. one of the wires from the relay goes to the ign wire and one to the starter wire both at the ignition harness. Then the last wire from the relay is the ground.
For Sale 98 Eclipse GS, 5 spd
Old 06-22-2004, 06:51 PM
michaelg98 michaelg98 is offline
Send a message via AIM to michaelg98
well there are several ways of doing it. the way that all of the directions reccomend taps it into the starter wire. so one wire is making the starter wire hot when you push it. most of the buttons also have a second wire that you just run power to for the internal light. i took out my ignition barrel altogether and put my button where you used to put the key. then i wired a hidden switch that turns on ignition power. my button just puts power to the starter wire when you push it. i utilized the immobilizer in my car alarm to cut beteen the starter wire so if you dont unlock the car with the keyless entry there is no possible way of stealing it. unless you were watching me when i installed all of this stuff. any momentary button works. its fun thinking of places to hide it
