| Engineering/ Technical Ask technical questions about cars. Do you know how a car engine works? |
#16
Re: Wat is VTEC???
YEs oops, yes
2002 Acura TL Type S 1991 Honda Crx Si |
#17
Re: Re: Wat is VTEC???
In a nut shell a lower duration cam lobe runs for economy under XXXX rpm, when it hits XXXX rpm, the vtec solenoid opens and fills a passage way with oil, which locks the rockers and engages the secondary cam lobe, which is of higher duration, and not economical, but makes more power. That is the magic of vtec (or any variable valve timing system) it (they) allow for normal operation and economical fuel consumption, while maintaining a sporty top end.
If it switched between cams we'd have quadrouple overhead cams.
Re: Wat is VTEC???
i didnt say cam shafts i said cam. a cam SHAFT has lots of cams on it. ie cam lobes 1 DOHC vtec cam SHAFT has 12 little cams on it thats why its called a cam shaft. out of thoes 12 little cams 4 of them are high duration.
#20
Re: Re: Re: Wat is VTEC???
but beleve me i am awair that b series engines are DOHC engines QOHC i have a dissasembled vtec heas at my shop rite now |
#22
Re: Wat is VTEC???
True. When people say cam, they mean cam shaft.
