Go Back   Automotive Forums Car Chat > Engineering/ Technical > Forced Induction
Forced Induction Discuss topics relating to turbochargers, superchargers, and nitrous oxide systems.
Old 06-17-2004, 08:14 PM
scallywag scallywag is offline
Re: Nitrous Oxide Pros/Cons Questions and Comparison
Originally Posted by T-Racer
well most nitrous is the same, i just like the white bottle better.
All nitros is the same There are so many different set ups available these days, I would hardly call them all the same. I would say go with the Zex kit. it is easy, and pretty fool proof. Probably one of the safest kits (probably because they are usually used for smaller shots into the throttle body if I am not mistaken...could be though!). And I am assuming you are just going to install like a 50 shot or so. That would be a decent shot for you. Really you should never run a shot larger than 50% more than your car already makes. And that is the limit unless you want to really screw things up. For instance say a gsr b18c1 has 170hp, you could potentially run a 80 shot, but I would not recomend running that much because the more you run the more risk you run of damaging your motor. I would say run between 40-60 with that motor. I don't know what kind of power your motor makes, but I would say keep it sumwhat low!
Old 06-20-2004, 08:37 PM
Kang114's Avatar
Kang114 Kang114 is offline
hey, u guys seem to know alot about nitrous and well, im wanna set up a nitrous system in my car soon but i have literally no idea how this stuff works. i was wondering if u guys could give me a quick 101. i have an h22 prelude and want a good system...
Old 06-20-2004, 10:35 PM
1gspot's Avatar
1gspot 1gspot is offline
Send a message via AIM to 1gspot
use the search, this forum is now about barney purple only....i say paint the bottle. that or they should send u some fruit with the kit. no offense to zex i love u guys
Old 06-21-2004, 03:04 AM
civicHBsi91's Avatar
civicHBsi91 civicHBsi91 is offline
Send a message via AIM to civicHBsi91
zex and honda go hand in hand.
If you want to spray your lude I would say zex 55 shot. keep it small until you learn more about it.
I would advise you learn some about it before you even get it, it will help you out.
2002 Acura TL Type S
1991 Honda Crx Si
Old 06-22-2004, 04:20 PM
mrchris1979 mrchris1979 is offline
Re: Re: Nitrous Oxide Pros/Cons Questions and Comparison
Here is my set-up that cut 2 seconds off my 1/4 time. I have a CRX with D16a6 SOHC non-vtec motor with stock internals and a 50 shot NX wet kit. 1) Start with a wet kit such as ZEX, NOS or NX. 2) Air/fuel gauge 3) NGK Spark Plugs BKR7E-11 these spark plugs are colder than stock and it works great on daily driven cars. I prefer wet kits primarily because the extra fuel needed is supplied by the fuel solenoid. The fuel delivery works independently and with the NX kit a fuel pressure safety switch can be added to cut off nitrous flow if the fuel pressure drops. I eventually added an MSD digital-6 ignition upgrade because my stock coil in the distributor could not keep up with the extra pressure once nitrous was used. If you feel hesitation or even hear a loud popping sound from your exhaust once you spray, that means that your ignition needs more spark. On the H22 you can start off with a 50 shot and leave everything stock but at the 75 shot range consider an igniton upgrade. Honda coils produce weak spark on any forced induction set-up. If you want an easy set-up start with ZEX wet kits. Hook up three wires and your good to go. I like NX because you can keep upgrading the system if you decide to go further with nitrous like going 100+ shot or full race set-ups. Also with NX, actual wheel HP is gained. I've proven to myself the power of NX. I ran 17.5 all motor to 15.3 on a 50 shot. That is respectable time considering I have AC and no cuts on the overall weight of the car. I can keep going on this topic, but if you need specific info, post it.
Old 06-22-2004, 04:31 PM
I'm just wondering why your 55 shot only cut .4 sec off your 1/4 time. I think a 14.7 pass on an all motor is excellent but once you spray I would think you could be on the low 13's. When do you activate the nitrous on your set-up? I ran a 17.5 all motor on a full interior and A/C SOHC 1.6 CRX and with a NX 50 shot I ran a 15.3 with street tires. I spray from launch all the way to 4th gear so maybe you spray later. Just curious.
Old 06-22-2004, 04:45 PM
Assuming that your motor is in good operating condition, a 50 shot should be plenty with stock internals. I posted on the next page what I have set-up in my CRX. On 1.6L 4 cylinder motor stay on the 50 shot range on 1.8L or larger motor a 75 shot is managable but I would consider an igniton uprgade to give the spark plugs more spark once nitrous is applied. The MSD digital-6 is perfect for nitrous users. I like the performance of the NX wet kits. I proved to my self that it can cut 1/4 time up to 2 seconds on a daily driven car. Like a lot of people say, if you want an easy install start with ZEX. The NX kits have more wiring, but it is not that complicated. The detailed wiring diagrams are easy to follow. Plus with NX you can upgrade the system for more power especially if you decide to go direct-port or build up to a full race nitrous set-up.
Originally Posted by k3rnel
hey
i am wondering what the pros/cons of n2o is and what the maximum safe boost i can achieve on a stock 4 cyl. engine.
also, what type of system should i install?
what kind of company should i go with? NOS, Zex, NX?
thanks for your help.
Old 06-22-2004, 11:48 PM
th_james2003 th_james2003 is offline
i agree i also have a nx 50 shot it is also a wet kit. with slicks i pull a 1.75 60 foot lanching on the bottle and not letting off till te end. i dont have a 1/4 mile track but i do have a 1/8 mile track. my times on motor are 8.6 and with spray i ran a 7.88. also the instalation time was only a couple of hours, and that was taking my time. a couple things i would recomend doing is upgrade fule pump and injectors for tunning and get a bottle warmer last a good air/fule gauge and pressure gauge.
Old 06-23-2004, 01:46 AM
Re: Re: Re: Nitrous Oxide Pros/Cons Questions and Comparison
this was the 1st time at the track with nitrous and shifted slower than normal just trying to keep it safe cuz I was not fully comfortable with spraying it was the 1st night I sprayed the car ever. I havent been back to the track yet. but I will see 13's.
I also have a broken motor mount so both all motor and nitrous time's will fall greatly when that is fixed and the nitrous time will drop because I have sprayed many time's since then and I am now comfortable with it.
Also cutting 2 seconds off your time....did you only run 17.5 once and then spray and run a 15.3? or did you pull consistant 17.5's and then spray? If you only ran a 17.5 once and then ran with the nitrous the 2 second's could be alittle dramatized. but none the less it made your time quicker than it would be all motor.
1991 Honda Crx Si
Old 06-23-2004, 11:51 PM
What is your tire/wheel combo upfront and where can I buy them? I'm losing so much time on the launch due to weak traction I currently pull 2.47 on the 60 foot and by the time I hit the 1/8 mark it is at 10.07 and end up at 15.48. If I can cut a second off my launch, I'll be content with high 14's on the 1/4 mile. Do you also have anything modified with your tranny ?
Old 06-25-2004, 12:11 PM
my wheel combo is racingheart 15 in rim wit m/t 20.0/8.0/15. no tranny mods just a b16 tranny.
