#16
Ok first of all, my van has 1 fan.
The fan has 4 wires. The temp sensor is connected to the temp gauge. My van has only 2 relays. High speed and low speed. The part number for the sensor is 077119003 170 degree sensor and it cost 16.99 It attaches on the upper radator hose, it straps around it, then I wired it to a NEW relay and then to relay to the fan. It is really simple to hook up. With the sensor from jegs they give a simple diagram on how to hook it up. I did use a fuse, I used a 30amp. You NEED a relay! The fan draws way to much current for the sensor to handle. You can be a relay at any local auto store or from Jegs if you wish. If I were you I would be the senors and get a relay and fix it so it does not boil over, over heating is really bad for the engine. |
#17
John, I ordered the Jegs Perma-Cool Fan wiring kit $17.99
It comes with the 170 degree Sensor, fuse and wiring. I also ordered the Perma-Cool A/C Relay $7.99. They say you need it for a 2 fan system. We'll see how it all ties together on their instructions. The bummer is that living in Alaska the shipping and handling is more than the parts! Still better than taking it to a shop I think. Thanks for all the help!! I will let you know how it goes. Thanks again!!! Mike |
#18
When my van first broke down (overheated when stuck in traffic) I had the van towed to a garage and the person there told me that the fan was bad he gave me price of $379.00 for the fan plus labor.
I drove the van home, hoping not to get stuck in traffic again, I went to a local junk yard and got another fan for $100.00. I put it in and I thought that was it, all done. I let the van run and it over heated again, thats when I went and checked everything out. I never would have thought that so many people have the same problem. Not just here but also at my job, 2 people have the same problem, one is a 91 and the other is a 92. This must be common problem for these vans, another poor design by chrysler. Why make simple fan such a completed circuit? It does not have to be that way, as I have proven. A simple temp sensor and a relay. It just works. The coolant gets hot and the temp sensor conducts, pulls in the relay, fan comes on. No need for high speed and a low speed. One more relay connected to the a/c clutch to turn on the fan when the a/c unit is on. |
#19
Better!
I got the Jegs order in today. I had a little problem figuring out how my van needed to be hooked up. I did not use the Diagram B but used Diagram C without the Relay for the A/C Clutch, mine has a seperate relay for that. The downside for this hookup is that once the van is turned off, the fan can still run until the temp is below 170. The first time it only ran for maybe 3-4 minutes. I don't know what kind of strain this puts on the battery as of yet. I think the battery end of the hook up can be routed with the ignition so it can turn off the power to the fan insted of waiting on the sensor. I will be looking into that.
All I can say is thanks to BigJohnJR.!! This fixed cost aprox $55 dollars! 50% of that was shipping up here to Alaska! I don't even want to know what a shop would have charged to fix it! I have liked my 92 AWD 3.3 Grand Voyager since I have owned it. I had to have a new transmission put in at around 30,000. Thank-you extended warranty! New struts, 2 starters, waterpump and this issue. The transmission has a clunk in it sometimes. I am worried about this in the long term. Other owners I know have it also. I guess I have been pretty lucky. Thanks again BigJohnJR!!! I am going to be a regular at this web site to see what else I can learn and hopefully share. Mike |
#20
Congrats on the install!
I still do not understand why they made a simple thing like a cooling fan so complicated. It does not have to be that way. Mine fan shuts off when I turn off the van, I did not want to kill the battery. John |
#21
Re: Thanks but still confused
Yes that is true, you can change the engine control modual. I tried to find one at the local junkyard and was told he wanted $200.00 for it.
For $25.00 I added a new temp sensor and it works perfect. Either way works. John |
#23
i think Whitney may have the answer. i just got the same problem this includes the following symtoms... over heating, resevoir overflowing, radiator fan quit, shortly after this in a period of two days the A/C quit. contacted a very close friend and mechanic, he said" check for fusible link by the starter. i didn't find one by the starter but after following the power wire(check to ground to see which this is) not the ground wire up the harness where it went to relay and changed colors and then under driver side hood hinge found wire changed to a very small 20 guage wire and orange. this wire was burned and after doing a temporary jump found it was the problem. still need to replace this with a lead and a fuse. this wire looks odd and i'm not sure how this small wire can carry the amps that the fan needs cuz it is so small. radiator fan works and A/C came back on immediately. cost of repair? 10 cents worth of wire, 2- 5 cent butt splices and 45 mins time. i love my mechanic. 92 dodge caravan 3.3
#24
Re: Overheating......Radiator Fan Not running... Help
stupid server this isn't the thread i was in.
#25
Re: Re: Overheating......Radiator Fan Not running... Help
on your 98 you have a fan relay on the bottom right as you stand in front of your car. it is below your cooling fans they run in my area about 80 dollars or check your local junk yard. also the relay may need new screws it is an update from chrysler for remounting this relay in a different spot on the inner driver side frame.. good luk kelly
#26
#27
1993 2.5 no a/c or fan
We had to pay someone to put a new fuel pump in our van. While they did that we asked if they could fix the A/C and the Fan they found that a Fuseable link went bad so now everything is workin.
#28
Re: 1993 2.5 no a/c or fan
Already replaced the fan and bought a temp sensor, But not installed yet. I would like to return the sensor or get the right one, if I could find the fuse you guys are talking about. Thanks for your help. BTW, It's damn hot here in Phoenix, so I have to fix this pronto! Thanks again... |
#29
On our van the fusible links were on the driver side under the hood they ran along the fender . If they are not there on your van maybe take it up to auto zone if yall have one and they should be able to pull it up and even show you.
#30
My daughters car, a 1997 Dodge caravan, cooling fan wasn't running.
The Service engine light was on with a 35 code. This code points to an open or short in the cooling fan curcuit. I replaced the Cooling fan relay, located on the drivers side frame member by the radiator. Has a 4 wire plug. Its an elecronic relay/switch. Napa carries the part but was out of stock, they wanted about $60.00. Got it from the local Dodge dealer for about $70.00. It was special order from Autozone. The part fixed the problem. |
