Old 03-20-2007, 10:52 PM
amxgilligan amxgilligan is offline
Re: 99 LX Windstar #10 fuse blowing
Yes, the part was a brand new factory dealer part. Cost the better part of $40. I also removed the rubber sponges on the top and bottom of the sensor electrical connector (which were soaked with fluid) and sprayed the entire connector with electrical contact cleaner.
Also, the fuse does not blow immediately, it takes at least 5 seconds before it blows. This makes me think it is not a dead short.
[email protected][/quote]
Old 03-21-2007, 05:30 PM
wiswind wiswind is offline
If you are saying that your new brake pressure switch was leaking......it is defective.....and I would replace it.
I would try to get them to make good on the defective part.....but either way......free or pay again.....I would replace it.
$40 sounds high....but maybe something is different for your year......still cheaper than a fire.
Moderator for Ford Windstar room only
Links to my pictures, intended as an aid, not a replacement for, a good repair manual.
1996 3.8L Windstar
http://www.flickr.com/photos/4157486...092975/detail/
2003 Toyota Sienna pictures (not much there yet)
http://www.flickr.com/photos/4157486...781661/detail/
Old 03-21-2007, 10:54 PM
No, the new switch is not leaking, but the fuse still blows.??? I don't know what to do from here.
[email protected]
Old 07-19-2007, 10:00 PM
I got a schematic from a local mechanic and traced the brake sensor wire to the cruise control computer. I removed the multipin connector from the computer and voala !- brake fluid with corrosion around two of the pins. One of the input pins was shorted to ground, therefore I was forced to replace the computer. A quick trip to Pull-a-part.com and $16 (including warranty) for a used cruise control computer and this fixed my problem. I now have cruise control and the fuse holds. I hope someone else can benefit from my tribulations.
[email protected]
Old 08-30-2007, 07:08 PM
-Baker- -Baker- is offline
Nice fixes listed....
I have a 2000 ford windstar also and the # 10 fuse is blowing now....wifey is mad and after reading these fixes I will have to try it myself. Wifey is starting to piss me off with her sarcasism of my doing??? by changing her brakes pads about 2 months ago. See... I change oil and filter and brake pads to save money and she just bitches about a fuse blowing...LOL runaround
Anyways I'll try this fix later and post back.
