Go Back   Automotive Forums Car Chat > Subaru > Impreza/9-2x/Outback Sport
Old 05-22-2002, 04:46 PM
Shyboy75 Shyboy75 is offline
Its all a matter of preference...if you lower your wrx, I don't think you'll lose enough handling to make it unbearable. In that, I'm assuming that you don't plan on doing any serious runs on the track or (obviously) any rally racing either. If you do plan on going out to the track, be prepared to spend some serious cash. I know, its been mentioned several times, but cheap parts = cheap quality.
The reason I do say that its not impossible to lower your car and still have a decent ride is that I've seen lots of lowered wrx's. Christ, look at the Cusco WRX. I know, I know, that's on a different level, but still, its possible to lower your car and have it handle the way you want it to. Its just a matter of how much money you have.
Old 05-22-2002, 11:06 PM
WRXTuner WRXTuner is offline
Send a message via AIM to WRXTuner
What's up with the double post?
Any ways you don't need a lot of money to lower your WRX I have the Tenabe lowering springs on mine as explained in the link I posted. THE BEST WAY TO LOWER YOUR CAR IS TO PUT SPRINGS Just needed that read. Anyways... Coil overs not coil over suspensions mind you are terrible, and coil over suspensions (i.e. Full suspension replacements) are very expensive. The best logical and most cost effective way to lower your car without losing total ride quality you get springs. If you read the post I have going on the springs in the link you will get more detail I just don't have time to re-type it all here
This is not all IMHO just facts.
Nick
Old 05-23-2002, 01:32 AM
ImportNut1212 ImportNut1212 is offline
Send a message via AIM to ImportNut1212
I dont think the best way to lower a car is springs....you only get one choice in how far its dropped. if you get a coil over suspension, you can adjust it to your needs, if you want it for show, drop it to the ground, if you want it for track, it you want it for street, etc. yes, a coil over suspension is expensive, but worth it, you are totally set up for looks AND performance. but drastically lowering a WRX is not smart IMHO.
original tofu crew member #06
my car=95 240sx se w/ s14 sr20det
lUcAs-----
Old 05-23-2002, 02:32 AM
I never said DRASTICALLY lower your WRX
I hate to say it but 2" on a WRX is not a major drop! The car has a 4" gap in the fender well in front and 3" in the rear! You put a 2" drop on the car and you still have 2" in the front and 1" in the rear and that's not travel that's room between the top of the tire and the bottom of the fender well.
In my and others expert opinions lowering the car 2" is more a stock ride height then the way it comes. It's set up from the factory as a rally car. When you put the springs on you get a nice street-car and a great street rally car.
I agree you have more options with a coil over suspension I don't say know to that. For someone who doesn't have $2000+ to spend and wants a lower more progressive look as well as better handling I say go with springs for the $350 total installed price why not. Later on, when you save your $2000+ you go get a good coil over suspension if feel you have the need to.
I guess my point here is this... you are not going to damage the cars struts by installing springs, even ones that lower the car 2" because the strut travel is not decreased beyond the point of which the strut is designed to handle.
Nick
Old 05-29-2002, 11:52 PM
mattwrxroy mattwrxroy is offline
OK guys. The bottom line is that it all depends on what sort of driving you want to do. Street, Track, Drag or Off-Road.
Whiteline have spent a fortune ($$$ and time) researching the WRX suspension, for both the old and new models and they have some very good packages available. I'm not sure who cheap they would be to export to the US.
But if you want expert opinion on this subject all you have to do is go to:
www.whiteline.com.au
Cheers !!!
Old 07-06-2002, 12:58 AM
rex4ev rex4ev is offline
Send a message via AIM to rex4ev
check out what these experts have to say on the subject...
http://rallyperformance.com/Suspension.htm
Old 07-09-2002, 11:45 AM
Gonthrax's Avatar
Gonthrax Gonthrax is offline
Skyline Guy
Send a message via AIM to Gonthrax
Lowering a WRX makes just as much sense as lowering any other car... Lowered center of gravity and all the handeling pros that come with it. Along with the handeling pros of a stiffer spring. If you do it right and buy the springs and shocks then you have just done somthing to significantly improve the handeling of your car.
As far as the opinion that lowering a WRX will screw up the apparently "Perfect" tuning that Subaru did. When a car company releases a sport sedan like the WRX, they tune it to appeal a little bit to a large portion of the market. If they only wanted it to appeal to the car enthusiests who wanted a performance ride, they would have released it with a more sport tuned suspension. However, half of the people who bu the WRX are people who just want a sporty car to drive to work, or pick up the kids in. They don't want a rattle your teeth, dropped to the ground suspension. So, Subaru hasn't tuned the WRX's suspension to the limit, and I would also venture to say that STi springs that lower your car say 1.5" are just as good as H&R or others that lower your car the same amount. So whatever you do, be sure you get the other associated bits
Member of AF's Slide Squad (Member #04)
Originally posted by taranaki
Postcounts - Phoey....it's not how often you speak,it's whether you actually say anything that matters.
Neishlin Motors
Soon to be my best friend
Old 07-09-2002, 02:44 PM
you have to be careful when you start messing with the suspension. the car handles great stock, and if you want to improve it you should get a whole set up, not just springs. if you dont care how it handles then springs may be the way to go.
quote from scooby sport, http://rallyperformance.com/Suspension.htm
"RallyPerformance and Scoobysport do not sell "lowering springs" without properly matched dampers, because they will ruin the handling of your Impreza."
-"Oh no! That four-banger has a turbo!"-
Old 09-11-2002, 11:54 AM
sico22b sico22b is offline
Send a message via AIM to sico22b
ok i know cheap lowering was the key term there but i ust figured that if u decide to change yur mind you should definately go with a nice set of coil overs, try here: scoobysport i'm planning on getting leda coil overs when my rs comes in. whatever you decide remember its yur car and its yur decision. don't let others tell you how to mod if you think differently. good luck dude!
Old 09-12-2002, 12:26 AM
creature creature is offline
Send a message via AIM to creature
I figured i would ask since it is on topic i was thinking of lowering my wrx but with a good set of coilovers. the car will be for show mainly will i still have a good ride with the good coilovers?
1995 dodge neon(hooked up), 2003 suby wrx(soon to be hooked up) :-D
Old 09-12-2002, 01:45 PM
coil overs in general are not going to give as smooth a ride as the stock suspension on rough roads. but it will decrease bounce over slight hieght changes int he road at higher speeds. from my experience the better the coil overs the better the ride is as far as coil overs go.
Old 12-05-2003, 09:42 AM
kfoote kfoote is offline
Re: how do i lower a wrx?
The Bilstein PSS9 kit for the WRX works quite well, and the ride is very good with a significant improvement in handling. It is designed as a street kit, so it's not as stiff as some of the other kits out there. The only issues I have run into are because of differences between the WRX and the STi, and that the kit was designed for the WRX, not the STi.
2004 Subaru Impreza WRX STI (daily driver)
1999 Mazda Miata (track car, slow, but finished the SCCA Runoffs)
1987 Porsche 944 (being rebuilt)
Old 12-05-2003, 05:03 PM
LjasonL's Avatar
LjasonL LjasonL is offline
Some Guy
Send a message via AIM to LjasonL
1 and 1/2 inch drop = perfect
Actually it would have been a bit more perfect if it was 1 and 1/2 front and 1 rear.
Old 12-13-2003, 06:44 PM
WCPWRX WCPWRX is offline
Banned
Send a message via AIM to WCPWRX
Originally Posted by wrxfl
somebody please tell me the cheapest ways to drop the wrx? I have read that the sport tuned suspention prevents you from just putting on cheap springs and it will ride horribly if you do. so what are some other cheap ways that wont totally mess up the handling.
Please give us a ring here at the shop
We manufacture our own suspension for the impreza that are not to bad for a inexpensive 0-3 drop for your vehicle.
We also offer other options also.
888-486-8449
WildCards Performance
http://www.wildcardsperformance.com
Old 01-09-2004, 12:56 PM
skills skills is offline
Send a message via AIM to skills
first to answer the 1st and main question "how to lower a wrx". i would say one of the best ways if you just looking to lower you wrx would be to get a set of tein s-tech springs. if you check out their site you will notice that the lowering rates for the front and rear are WAY different. but this almost evens the car out and at $175 or what ever they are going for these days is a pretty good deal. i originally had whiteline flatouts and they suck! very bouncy. if you are looking to to do it the right way i would highly suggest getting a set of true coilovers. i am currently running on DMS 40s and love them. quite spendy but in my opinion they are worth it because of the huge hight adjust ment and the 30pt. damper adjustment and hey being fully inverted is a plus for me also.
now to those of you who are saying dont lower you car because you are ruining the rally car look and the wrx was not intended to be lowered. look at all the different manufactures in the wrc over the past 5-7 years they all get lower and lower. its not all about the lowered stance alot of the suspension has to do with the dampening and overall feel of the car. im sure all the mechanics and tech guys arent saying "hey i think itll LOOK alot better if we lower it".
The New Subaru Canada WRX STI Spot subarucanada General Discussion 1 07-13-2012 01:44 AM
FS/ WRX Powered Justy on Ebay Theon315 Cars/Parts for Sale/Exchange 0 05-06-2010 10:42 AM
Lowered BMW problems... :-( Ashleyyy 3 Series 0 04-18-2010 12:30 AM
WRX and similar cars dtmerino Car Comparisons 7 02-07-2010 07:08 PM
Lower radiator hose cool/Water pump squeal ktl4974 Problem Diagnosis 7 05-04-2009 08:44 PM
