Old 06-05-2004, 10:47 PM
SickVette SickVette is offline
Send a message via AIM to SickVette Send a message via MSN to SickVette Send a message via Yahoo to SickVette
Re: new to car audio, need help
PaulD...you refer to the bandpass as a higher order. Technically that is not true. Cabinets were started to be labeled in orders due to their simularity to a certain order xover. So calling a bandpass a "4th order" is really using an applied term that was given through time but not a true definition. I guess you could call it slang. Now bandpass enclosure have been given a bad rap in SQ circles due to they are really intended to provide a high amount of output at a given frequency. The higher the output at that frequency the narrower the bandwidth. But if you widen the bandwidth the frequency spike will drop and you can have a good sounding bandpass. Or as was said you can use a very strong midbass driver(s) to fill the gap to the midrange. On the flip side if you build a bandpass to have a wideband you are defeating the purpose of using that type of enclosure and creating a overly large enclosure. One that will give the same results as a smaller ported or sealed enclosure. Either way you can still build a bandpass enclosure that has good sound quality charcterists...I know. I have done it. Do I recommend it....no. Personally I prefer sealed enclosures but that is entirely different conversation.
1999 Corvette coupe 600rwhp and way too much stuff to list everything here.
Audio Pioneer AVH P7500 DVD w/xm
2 PG Ti 600.2
1 PG TiDEQ
Stinger battery,alternator,wire,cap,fuse blocks
1 JL 12w6v2
1 7" monitor in rear
MB Quart 8" 4" and tweet in each door
Custom fiberglass,plexiglas, and aluminum amp rack
carbon fiber sub enclosure
Old 06-05-2004, 11:42 PM
Haibane's Avatar
Haibane Haibane is offline
Send a message via AIM to Haibane
And that right there tells me exactly what I was trying to get across, but also a few things I didn't know, like how you could have a good level bandpass.
www.cloudcity.deviantart.com
Old 06-06-2004, 03:51 PM
aznxthuggie's Avatar
aznxthuggie aznxthuggie is offline
Re: Re: new to car audio, need help
Originally Posted by sr20de4evr
Bandpass boxes can sound good, just like Paul and Vette have said though, it needs to be built (and above all, designed) very very well. Most people have only heard prefab bandpass boxes, just like prefab ported boxes these are 1) not built for the specific sub (normally) and 2) built to get very loud at a few frequencies to give the "wow" effect, while ultimately giving you a horrible response curve. Just like with ported boxes, if you want to build an effective bandpass box with good sound quality, you have to design and build it yourself, the only difference is the bandpass will be much harder than the ported box.
Now, back to the facts, aznxthuggie - building a box is easier than you think, give it a try, you might be surprised. Lets see, all the enclosure sizes we give are in cubic feet, by definition this is a cube where each side is one foot long. To get the volume of the box you just take the lengths of the sides (in feet), making sure to subtract the thickness of the wood, and multiply them together, thats it. If you have a box that is 2' x 1.5' x 1', it will be 3 cubic feet, pretty simple. Then you just add in a little extra volume (make the box a little bigger, how much bigger depends on the specific sub you're using) to account for the space taken up by the sub itself, and you're golden.
hmm lets say i do find out what kind of box i need, and the dimensions and everything, since i am going to buy wood frmo home depot, do u think it'll be easier if i just pay them to cut it, i think its a little $ per cut, they do all the cutting, you give them the specs/dimensions? also.. what do u have planned for your audio overhaul? or will we know when your done heh
Old 06-06-2004, 06:50 PM
sr20de4evr's Avatar
sr20de4evr sr20de4evr is offline
Re: Re: Re: new to car audio, need help
Home Depot cuts aren't very accurate. I'm sure if you give the guy a few extra bucks and tell him to make it exact he will, but normally they just get it close and cut away. The few cuts I've had them make have all been 1/8 to 1/4" off, which will REALLY screw up your box.
And I'll post a thread when it's all done, ordering the first piece in about 3 days and it should take around a month to finish (it sucks building a system from paycheck to paycheck).
'01 Black Sentra SE
Weapon-R intake, HS header, HKS catback, ES motor mounts, B&M short shifter, Tein coilovers
Alpine 9835, Adire Koda 6.1, Adire Brahma 15, Arc 2100cxl, Linear Power 2.2hv, Cadence ZRS-8
'05 Silver WRX STi
Injen SES Downpipe, HKS Carbon-Ti catback, Cobb Stage 2 Tune, TiC Super Shifter, TiC Klunk Killer, Tein springs, Nitto NT555R Drag Radials
Old 06-06-2004, 09:12 PM
sr20de4evr....is correct and it is very sad too. Since all the Home Depots here have panel saws, which are much more accurate,safer,and easier to use than a table saw. It is really sad that most of the employees can not make a square cut with one.
2 PG Ti 600.2
1 PG TiDEQ
1 JL 12w6v2
Old 06-06-2004, 09:35 PM
n_samedi n_samedi is offline
wow, thanks for the responses guys. i didnt mean to bring up so much drama, lol, but i appreciate all your opinions. thanks again.
Old 06-06-2004, 09:48 PM
heh its ok we do this all the time, im a newb also =D
Old 06-06-2004, 10:00 PM
PaulD PaulD is offline
Audio Guy
Send a message via AIM to PaulD Send a message via Yahoo to PaulD
Actually, it's a very accurate term - a fourth order box has a roll off very similiar in nature to a 4th order crossover. It's just a natural transition. The very nature of the thiele/small parameters was to model a box/speaker program as electronic components in a circuit. It can very accurately predict the performance of a box/speaker in a large room. The trick has been to take into account that a car's bass sysytem is enclosed in a realitively small enclosure.
Old 06-07-2004, 07:07 PM
Damn I forgot something. n_samedi on your sisters car there are a few things you can try on the trunk that are free.On the two outer corners of the trunk there are rubber stoppers. Those are adjustable. The latch in the center is adjustable also. What you can do is adjust those three things till the trunk close very tight. You have to lower the latch part that is inside the trunk and first raise the rubber stoppers. When you get the latch lowered to the point where you can still latch the trunk you lower the stoppers to push the trunk back up a little so it is flush with the quarterpanels. Then ofcourse you can use sound deadning materials.
that worked so well, thanks. the latch didnt move too much but i think its the rubber stoppers that did the trick. there is no more rattling and my sis isnt embarassed to turn her sound up! thanks!
Old 06-07-2004, 09:06 PM
sweet n_samedi....glad it worked for her.
2 PG Ti 600.2
1 PG TiDEQ
1 JL 12w6v2
