Go Back   Automotive Forums Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 06-02-2004, 10:21 AM
WaltonsMtMan WaltonsMtMan is offline
replace the fluid in your tranny with a really good synthetic fluid...change to synthetic oill.....thats good for a mpg or so...
whats your air intake look like...?Stock....? say it aint so.....
i have the same truck...lets talk shop...make your own high flow intake...its easy...ask me how...the way the air hose runs into the sidewall is got to be the worst...look how ineffective that is....Crazy design....anyway...the airintake fix will give ya some more power and some mpg increase 1 or 2.....
add a magnaflow or flowmater muffler for about 120.oo and get some more hp and mpg...
do the pcm mod ..FREE !!!!!.....more power....
DEFINATLY GET THE TRANNY FLASH FROM THE DEALER...80.00 bucks...
those things will add about 3-4 mpg and quite alot of horses....
oh and by the way...Youve Got the DEATH FLASH !!!
Old 06-02-2004, 01:43 PM
BleedDodge's Avatar
BleedDodge BleedDodge is offline
Send a message via MSN to BleedDodge
Re: Help! Need better gas mileage
What is all this about the death flash?
Old 06-02-2004, 03:47 PM
Look on your pcm...if there is a barcode type sticker on it that says something like....factory software update blah blah blah...then you got it man....its like some crazy asian VD>......cant get rid of it....
dodge trucks had some pinging problems so instead of fixing it on god knows how many trucks they just "Flashed", reprogramed your pcm to back down about six points worth of timing......Cured the pinging but guess what....Lost a shit load of HP...and MPG's......there is a pcm mod that you can do real simply to help ......and of course the basics...air flow....exhaust.....synthetic fluids but its uncurable....a programmer will get back your timing since you can manually override and reprogram your pcm.....
the flash happend in the factory before you got your truck or when you took it for service...they dont even ask ya...just zap
Old 06-02-2004, 03:59 PM
BleedDodge's Avatar
My truck has always pinged, and always gotten horrible mileage. I got it new, and it's never been reprogrammed, although the mechanic told me there were computer updates available, I didn't let him do them since he wanted too much money for it.
I'm inclined to believe that mine was not "death flashed" since it pings like crazy, but it gets real bad mileage anyways. It doesn't really bother me that much since I'm just gonna eventually replace the motor with an older one once this one takes a crap...
Old 06-02-2004, 07:20 PM
dominicdlm3 dominicdlm3 is offline
Its not just your truck it is the 5.9 that is causing your bad gas mileage I have a 2001 4x4 ram 1500 with the same problem
Old 06-02-2004, 09:47 PM
slantsixness's Avatar
slantsixness slantsixness is offline
GEEZ,
The "death flash" has caught on.....again!
Guess we'll all be looking for that pcm with the "update" on it....
Yawn----- this is old news guys...
If I knew what I did to break it, I would've known not to do what I did.
www.classicwinnebago.com
Old 06-03-2004, 09:20 AM
Re: Re: Help! Need better gas mileage
Originally Posted by slantsixness
GEEZ,
You act like its just a rumor or something....Well folks i can only say if you got it you can "fix" it.......at least comansate for it......im sure your yawning alot sitting in that 6 cyl.....i know i would be.....
As far as old news it seems quite a few folks dont know......I mean just cause your slowwwwwww doesnt mean we should all be....
So you guys can look for your sticker, verify that ya got it and come away with some understanding of why your truck is driving like a pig.......
Mine used to......doesnt now.....!
Old 06-03-2004, 12:41 PM
SUMOBOY SUMOBOY is offline
After installing a K&N air filter, new plugs, coil and wires, msd ignition box and new fuel filter, I'm up to 10.2 mpg on my 95 ram 360. Hydrocarbons are still way too high, so maybe the injectors are shot. At 200,000 miles, you think?
If you don't have the toll money, can you still get to the light at the end of the tunnel?
Old 06-03-2004, 06:35 PM
Dodgeintheblood Dodgeintheblood is offline
To Seniorbigs,
The second o2 sensor only reads heat and a higher o2 concentration then the first sensor. We just weilded an enclosed bracket houseing to the outside of the exhaust pipe for the o2 sensor to screw into. I just got back from a 600 mile road trip and have yet to see a code, and my gas milage was 18.6 mpg. After finding out how to get around the o2 sensor i just got a section of three inch exhaust pipe and made bridged the gap where my cat used to be.
Old 06-04-2004, 06:49 AM
Re: Re: Re: Help! Need better gas mileage
Dude, get off your high horse.
Death flash has been around 5 years, and most of the time, It's been fixed already.
You don't know what trucks and cars I have or had, or what I know.
I have preferences maybe that you might not like, but don't slam me because I like a slant six...(only two of several vehicles...) You could learn a little about the leaning tower of power, and put your foot right back in your mouth, and off my back.
Lastly,
Walton's Mountain isn't in Alabama anyway, so what gives with the name?
Do you even know where Walton's Mountain is?
It's ok to have fun at my expense, just remember, I'll have more fun at your's.
Slantsixness
(somewhere a lot closer to walton's Mountain than you are.)
Old 06-04-2004, 07:02 AM
Condor Condor is offline
Send a message via ICQ to Condor
I used a quart of the lucas head decarbonizer and ran 80-90 for 400 miles. It made a big improvement. Car like yours you would need 2 qts I think to have the same percentage.
New O2 sensor does always seem to help the gas milage. Wider tires definately lower the milage. Tune it up really good. You knew that though.
I was down to 22 mpg for a bit cause of the O2 sensor. With the above and included are my wide tires and I dont have the spoiler on, I went back up to 39. It's epa rated 32.
If you have an aftermarket O2 sensor make sure you solder the wires not just twisty them. It can make a huge difference and not throw a code.
Good luck.
87 CRX Si , bought new, no rice
[color=black]2003 Honda VLX, bought new,((sold for new wife)Long gone and good riddance: 70 MGB stock, 71 MGB modded, 92 mustang HP car modded
99 323 IS totalled by maniac in monster truck
current ride: 93 325IS black on black with good radio only option
Old 06-06-2004, 07:57 AM
sadlerb_98's Avatar
sadlerb_98 sadlerb_98 is offline
Send a message via Yahoo to sadlerb_98
Hello guys,
I am back but haven't had a chance to drive much. I replaced the spark plugs, air filter (looked good), etc. The tires are the original size that came on the truck (265/75R16). In fact they are still the original tires. I also bought some fuel injection cleaner and put into the tank. It might take some time for it to run through considering I have a 35 gallon tank.
Thanks,
Bob
Old 06-06-2004, 09:06 PM
sadlerb_98's Avatar
I must be getting better gas mileage now. I am not even at a half of tank and I am already around 275 miles. I usually don't get 200 miles before the halfway point. Will let you all know once the tank is empty.
Thanks,
Bob
Old 06-07-2004, 06:08 AM
TRAILDUSTER79 TRAILDUSTER79 is offline
Send a message via AIM to TRAILDUSTER79 Send a message via Yahoo to TRAILDUSTER79
Hey Bob, No One Has Mentioned At All About Getting Rid Of The Automatic And Putting A Manual In, Big Boost In Milage, Pulling And Ponies, Besides The Engine Wont Work As Hard Because It Has More Gears To Choose From..........now, The Other Thing Isyou Have A 360 Right....well Unless You Let That Thing Run It Will Suck The Fuel......i Have A 79 Plymouth Trailduster 4x4 W/ 33" Tires On It And A Edelbrock 4 Brrl With Headers And 2" Exhaust.....32 Gallon Tank At Speed Limit I Average 300 Miles.... Put My Foot To About 90 And I Get 500 Out Of It...dodges Like To Open Up And Run, Just Watch Out For The Cops
Old 06-07-2004, 04:41 PM
sadlerb_98's Avatar
Thanks for the reply. I probably do need to open it up some just my my harley I used to have. I am looking into an exhaust system and intake. I will probably get something in the near future.
Thanks,
Bob
