Go Back   Automotive Forums Car Chat > Buick > Regal
Closed Thread Show Printable Version Show Printable Version | Subscription Subscribe to this Thread
Old 07-24-2005, 10:31 PM
bubble.tea bubble.tea is offline
Re: '99 Regal Dual Climate Control Driverside Hotter
Originally Posted by tlvanhoose
Well, my brother-in-law has a friend that is a mechanic and he looked at my car and it was way low on freon(spelling?). He filled it up and said that isn't uncommon that one side blows out hotter that the other when the freon is that low. Maybe that is your problem, also?
yup..happened to me. It was low
  #17
Old 04-17-2008, 08:57 PM
AustinPowers3002 AustinPowers3002 is offline
To fix this especially if you were working on the electrical system like I was (disconnected the battery) the problem is the computer needs to reset. To do that connect the red positive cable to the positive terminal on the battery. Wait 30 minutes to 1 hour then connect the black negative cable to the negative terminal on the battery. You can then test to see if cold air comes out both sides. When you start the car for the first time the time on the radio will need to be adjusted and the climate control head unit will start in the AUTO setting somewhere in the 70-78 degree range. You will need to drop the temperature to 60-65 to see if the air is getting cold on both sides. The reason I mention this is because I thought it was still messed up but then I looked and saw that once the climate control was reset it was no longer on the 60 degree temperature I had it on but was at the reset value of 75 degrees which is heat.
  #18
Old 04-17-2008, 09:12 PM
HotZ28's Avatar
HotZ28 HotZ28 is offline
AF Moderator Elite
Posting in Closed or Outdated Threads
Closed Thread
